My new mall crawler / DD
:clap:
Man that is a clean 1988. I would hate to wheel that one. Too nice to wheel, but a great DD or light wheeler.
How do you like that front suspension lift kit. I was wondering how those perform, drive, handle etc. I have one I got for cheap and was wondering if I should put it on.
What size of tires are you running on that set up?
Sweet truck:flipoff2:, I'm jellous.
holy ****
That is just absolutely unreal,is that restored or stock condition?definitely a mall cruiser but sweet ride.i love those 1st gen 4runners.
:hhmm:How did you get such high level of detail to come through on your Matchbox photos?:lol: BTW, Nice find with that rig.
It is most definitely restored. It has 336,000 Miles on it. Maintained by the original owner until 2002 when he sold it. Second owner had it until October 2010. 3rd owner bought it and put close to $8k into it. Everything has been done, check out the receipts list:
Smog 60 5/29/2011
Registration 24 5/29/2011
Blaster Coil 49.99 5/15/2011
Fuel System Deep Clean 10.99 5/15/2011
Fuel Line 5.95 4/9/2011
Exhaust Clamp 2.49 4/9/2011
Vacuum Tees 4.99 4/9/2011
Steering wheel puller 16.99 4/9/2011
Muffler Clamps 12.5 4/3/2011
Cleaner/Lube 11.99 4/3/2011
Install Kit 24.99 4/3/2011
Puller 7.99 4/3/2011
Silverstar Ultra 49.99 4/3/2011
PCV Valve 4.99 4/3/2011
Permatex 6.99 4/3/2011
Fel-Pro Oil Pan Gasket 8.29 3/4/2011
Power Steering Pump 89.99 3/4/2011
High Performance Gear Oil 21.99 3/4/2011
Valve Cover 119.95 2/2/2011
Billet Oil Cap 26.95 2/2/2011
Valve Cover Gasket 22.95 2/2/2011
Alignment 55 1/31/2011
Tire Mounting 100 1/28/2011
Wheel Locks 60.88 1/27/2011
Power Steering Fluid 15.98 1/26/2011
Power Steering Pump 132.19 1/26/2011
Master Cylinder 65.99 1/25/2011
Brake Cleaner 7 1/25/2011
Conversion Headlamps 117.99 1/25/2011
Mickey Thompson 358411 Wheels 410.36 1/24/2011
Grease Gun 33.88 1/21/2011
Trans Hose 6.58 1/21/2011
Duralast Alternator 79.99 1/20/2011
CV Half Shaft Axle 100 1/20/2011
Sway Bar Bracket Bushing 8.99 1/20/2011
CST Radiator Cap 8.99 1/20/2011
Fan Clutch 39.99 1/20/2011
Oil Gasket 8.29 1/20/2011
Radiator 135.99 1/20/2011
Street Header 383.95 12/16/2010
Radiator Hose 74.95 12/16/2010
Stainless Brake Lines 94.95 12/16/2010
Front Sway Bar Bushing 12.95 12/16/2010
Oil Dipstick 18.95 12/16/2010
HD Torsion Bars 239.95 12/16/2010
Paint Top hood upper and lower valance 850 12/13/2010
Misc Nuts and Bolots 33.02 12/8/2010
Front Balancer Seal 9.95 11/30/2010
Front balancer Seal 9.95 11/30/2010
LC Pro Air Intake 214.95 11/30/2010
Catalytic Converter 299.99 11/30/2010
Alternator Bearing 25.99 11/15/2010
Idler Pulley 26.99 11/15/2010
Black Paint 7.99 11/15/2010
Front and Rear Seat Cloth 550 11/12/2010
4" 2 Way 135w Speakers x 2 79.99 11/11/2010
z Series 8 gauge amp kit 50 11/11/2010
Z Series 2 Channell Twisted Pair 22.99 11/11/2010
X Series 16 Guage Speaker Wire 24.99 11/11/2010
Multi Channel 150W Amp 204.99 11/11/2010
Vinyl Paint 6.59 11/11/2010
Primer 5.49 11/11/2010
Belts 178.81 11/9/2010
Clutch Master Cylinder 30.49 10/24/2010
Idler Arm 51.99 10/24/2010
Wiper Blades 19.98 10/24/2010
Wiper Blade 8.99 10/15/2010
12oz Stop Leak 9.99 10/15/2010
Battery 89.97 10/15/2010
Smog 78 10/15/2010
Crank Seal 9.95 10/15/2010
Oil Pump O Ring 13.95 10/15/2010
AC Belt 16.95 10/15/2010
Alternator Belt 18.95 10/15/2010
Intake Cleaner 35.2 10/15/2010
Front Rotors 100 10/15/2010
Front Brake Pads 67.05 10/15/2010
Replace Oil Pump O O Ring and Drive Belts and Crank Seal 192 10/15/2010
Throttl body and air intake clean and replace thermostat 65 10/15/2010
Brake Job 239.95 10/15/2010
Adjust Valves 89.95 10/15/2010
Adjust Rear Brakes 48 10/15/2010
Weatherstrips 42.85 10/11/2010
Stop Lamp 3.19 10/10/2010
Truview Light 20.24 10/10/2010
Mini Lamp 2.99 10/10/2010
Air Freshener 5.41 10/10/2010
Tri-Flow Lubricant 6.39 10/8/2010
Bulb BP194 2.23 10/8/2010
Fuel Kit 29.99 10/8/2010
Fuel Hose 1.29 10/8/2010
Mini Lamp 3.49 10/8/2010
Hose Clamps 2.99 10/8/2010
Chilton Book 19.99 10/8/2010
Air Filter 13.99 10/8/2010
1 Gal Antifreez 9.99 10/8/2010
Air Surge Gasket 191.42 10/4/2010
Spark Plugs, Cap, O2 Sensor, Valve Clearnce 356 4/27/2007
Engine Rebuild 905 10/30/2006 318 160 Miles .020 Over on bore standard on rods and mains engine wear was virtually non existant We Bored the block due to a couple of minor pitted areas at the top of the cylinder in #1 and #3. Mains & Rod journals were exactly on factory spec so we left them. The head was warped due to either a stuck thermostat or a tightly curved water hose under the intake. Street performance head with 268 degrees duration tourquer cam.
Surfaced Flywheel 30 10/30/2006
New Clutch 100 10/30/2006
Wire Set 31.99 10/15/2006
Plat Spark Plugs 20 10/15/2006
Anti Seize 4.49 10/15/2006
Tires 1119.56 10/22/2005
Oil Change 26 10/15/2003
Safety Inspection 78 3/28/2003
Oil Change 17 3/8/2003
Oil Change 17 12/31/2002
Oil Change 17 9/28/2002
Tires 359 7/25/2002
Engine Rebuild 2031.85 6/8/2002 Coolant in Clyinder 3. Head machined
Oil Change 22.67 5/25/2002
Oil Change 17 3/9/2002
Oil Change 17 1/12/2002
Oil Change 17 11/17/2001
Battery 79.99 10/8/2001
Alternator Check 40 10/8/2001
Paint Work 683.05 9/27/2001
Fuel Leak 228 8/29/2001
Transmission 1486.46 6/8/2001
CV Joints 466.31 3/23/2001
Water Pump, hoses, radiator 470.37 2/16/2001
Oil Change 17 1/29/2001
Replace Dash Indicator Bulbs 77.25 8/9/2000
Replace Blower Fan 213.09 8/4/2000
Replace Clutch Warranty 172.65 7/1/2000
Ignition 140.01 5/5/2000
Oil Change 17 5/3/2000
Oil Change 17 2/6/2000
Oil Change, Replace Muffler 155.74 11/29/1999
Clutch Replacement 609.84 11/9/1999
Tires and Shocks 608.83 10/4/1999
Radiator Cap and Thermostat 30 9/16/1999
Fan Clutch 55 9/8/1999
Radiator 267 8/18/1999
Oil Change 17 6/2/1999
Thermostat 77 5/2/1999
Head Gasket, Oil Change, Flange Gasket 1463 4/8/1999
Oil Change 22.07 2/5/1999
Brakes,Exhaust 864.15 10/10/1998
Oil Change 16.95 9/5/1998
Oil Change 17 6/13/1998
Tuneup 112.9 3/28/1998
Water Pump. Valves. Head Gasket. Timing Chain 1674.25 8/22/1997
Water Pump 259.71 8/4/1997
Oil Change 25.8 6/3/1997
Paint Work 250 4/29/1997
Reman Alternator 324.26 4/3/1997
Oil Change 24.17 3/27/1997
Valve Cover Gasket and Brakes 269.95 1/9/1997
Oil Change 24.17 1/4/1997
Bug Guard 60 1/3/1997
Oil Change 24.17 10/19/1996
Oil Change, Thermostat 96.38 7/20/1996
Battery 60 4/8/1996
Tune Up 367 4/8/1996
Oil Change 24 3/30/1996
Oil Change $20.00 1/20/1996
Oil Change Clutch master cylinder 163 10/13/1995
Oil Change 23 8/12/1995
Water Pump, Brake Job 395 5/17/1995
Oil Change 24 5/13/1995
Oil change and Tuneup 190 12/10/1994
Oil Change 24 9/12/1994
Oil Change 12 7/2/1994
Oil Change 12 5/7/1994
Oil Change 21 1/29/1994
Valve Adjustment and Oil Change, Thermostat, Plugs 568 11/20/1993
Oil Change 20 8/28/1993
Head Gasket, Oil Change, Flange Gasket 369.82 6/1/1993
Valve Adjustment 30 3/30/1993
Header Pipe and Gasket 60 2/23/1993
Oil Change, Spark Plugs, Valve Cover Gasket, Pipe 364.01 1/27/1993
Oil Change 31 6/26/1992
Oil Change 30.23 1/4/1992
Oil Change and Replace Alt Belts 95.39 12/5/1991
Oil Change 18.98 8/24/1991
Oil Change, Spark Plugs, Breaks 623 4/2/1991
Oil Change 27 12/15/1990
Clean Throttle body and oil change 75 10/23/1990
Oil Change 26 7/21/1990
Oil Change 13 5/9/1990
Oil Change and Air Filter 41 3/5/1990
Oil Change 24 12/9/1989
Oil Change 100 9/5/1989
Oil Change 26 9/2/1989
Resurface Drums 83 6/5/1989
Oil Change 49 6/5/1989
Oil Change 24 3/23/1989
Oil Change 13 8/20/1988
Hitch and ball mount 105.95 7/22/1988
Oil Change 18.55 6/3/1988
Oil Change 19.58 2/29/1988
TOTAL: 27698.02
TOTAL: 27698.02
Did you seriously type that out for our reading enjoyment? :clap:
I was just looking at your softtop thread. Awesome looking rig. Welcome to the madness! (I miss mine :crybaby: )
