My 2007's ML speakers are blowing one by one, probably just due to age, I haven't been beating on them by any means, I mostly listen to frustrating talk radio...
In any case, when I looked at the cost of replacing the speakers with OEM, it was absolutely ridiculous, so I began researching my options considering the proprietary nature of the ML setup. I'm fortunate enough to have been a professional installer back in the heyday of car audio (the 90's) so I've got a good handle on what needs to be done and what equipment manufacturers to go to. My first thought was to look at PAC-audio who specializes in bypassing or integrating with OEM hardware. I was happy to find this:
catalog.pac-audio.com
And this:
***UPDATE*** The AP4-TY11 listed above DOES work with the ML stereo, but the APH-TY04 listed below does NOT fit the ML amplifier, only the base model's JBL system...
AP4-TY11
Today's modern vehicle audio systems are becoming increasingly more sophisticated and complex. PAC engineered AmpPRO to dramatically simplify the installation of upgraded amplifiers in data-bus-controlled amplified sound systems. AmpPRO allows you to keep the original radio's fit, finish, and...
And this:
APH-TY04
Easily add amplifier(s) to Toyota and Lexus factory amplified systems without cutting or modifying the original wiring. Simplify speaker wire connections by using the APH-TY04 speaker connection harness when adding aftermarket amplifier(s) to select Toyota and Lexus vehicles. Featuring OEM...
