My LC Wont Go Into Reverse.... (Auto)
Dubai
So today when i tried to back up from my parking and shifted it into reverse the car would not even budge. Had to put in neutral and push the car back. Then i noticed while driving that it would not shift to sesond. Drove for about 2 kms like that but i did not push it . I was getting on to highway so i pushed it to about 4k and then it shifted and after that i did not any problems. Once i reached my workplace i shifted to reverse to park it and it s***ed with out any problems. Later on in the evening i put to reverse and again it would not shift.
Any advice would be greatly appreciated...
It is a 2000 Model 4.5 ltr..
I'd be doing one of the following:
Hunting down the appropriate FSM to troubleshoot the issue.
Just as an example this manual:
https://forum.ih8mud.com/attachments/a442f-testing-and-adjustments-pdf.1420894/
is for the A442F, which you probably do not have.​
Or
Trying to find a reputable transmission shop in your area (sometimes it seems the words "reputable" and "transmission shop" don't go together very well)
Or
I might add:
Stop driving it until you get it diagnosed and repaired.
  • Like
Reactions: jLB
Time to get a manual transmission. In your area, I am sure you can easily locate a 5 speed transmission.
From a 2000 TLC FSM (USA spec)
No reverse means low on fluid or clogged filter.
No upshift means low on fluid or clogged filter.
Working reverse but no upshift means solenoid or clutch issue.
