Did you get a new fuse box exactly like the one you replaced? Are you going to have the same issue with new box?Since I replaced the entire fuse box I have had zero issues.
For clarification - the jumper was fused and never blew the fuse and I pulled power from an un-used fuse location in the box. I can sent pictures but the output power past the relay was melting so the issue was downstream of the relay power and between the relay and ECU. The immobilized issue is caused by a voltage drop before getting to the ECU caused by resistance in the fuse box.
Toyota upgraded the fuse box in ‘02 or ‘03 and this eliminated the issue. I purchased a NEW OEM with the newest part number avaialble so I assume it is the upgraded fuse box. No temp increases on the fuses or EFI relay. If you have a temp gun you can take the temp of the fuses and relay. For me - they both got hot, as well as the wires. I dealt with the issue for about 4 years. Upsized the fuse - temp fix. Replaced the EFI relay - temp fix. I built multiple jumpers - off of the open fuses and direct to the battery. They all worked, but if I drove for a couple hours - they all increased in temperature. I upgraded the wires on the upstream side of the relay and the downstream got hot (the relay).Did you get a new fuse box exactly like the one you replaced? Are you going to have the same issue with new box?
There are a few things with hundys that is sure to happen at some time or another. Not many things but a few and this faulty fuse issue is one of them for a few model years. And when that has happened to many hundy owners here......the kit, the knowledge and assistance @medtro has provided over the years is significant and appreciated. And so far I would say it is a permanent fix for a fraction of cost and time.PS - You may have made a business out of selling the jumpers and while it may work for many people - it is not a permanent fix.
You clearly don’t understand the issue with the fuse box as a whole. The short and failure of the fuse box is the connection bar that is AFTER the fuse and relay. That is the issue. The short causes an over amperage draw on the original fuse location - blows the fuse, change the fuse - it starts for a while, upgrade the fuse - it starts for a while - eventually it will fail. Then put the jumper in - fine. Larger wires, they absorb the heat, amperage draw, etc and dissipate the heat, but eventually at some point - they will all fail. Look at the ROOT cause of the problem with the crank/no start - low voltage to the ECU. Why? If you have good voltage and continuity pre-fuse and post-relay - then it is in the box and that is the reason the ONLY permanent repair is to replace the fuse box.
Watch this video and it will help explain it - he pulled the fuse box apart. The same thing will happen to every fuse location you use.
As I understand it - Toyota upgrade the output side of the fuse boxes in ‘02 so this issue us generally only a problem in the early 100 series.
What is to prevent the problem from returning sometime after swapping in a new fuse box? Many years ago, I remember reading it was a design flaw which Toyota corrected in '02 or '03 by splitting the load from one fuse into two fuses?
The same problem arose on my '99 when I was truly in the middle of nowhere Nevada on an elk hunting trip. Fortunately we were traveling in pairs and I was able to hop a ride with my buddy and drive to just enough cell service to get a band-aid fix ala this thread to at least make it drivable until I could get @medtro kit. So far, some 10-years later @medtro fix is still working for me albeit its not a DD for me.
This is the first time I read about Toyota upgraded the output side of the fuse box in 2002. Based on the information from people who purchased the kit, 2002 LC/LX is not immune to the problem described in the first post. If what you said is true, then upgraded output side of the fuse box didn't address the problem before the relay. Someone with 2002 LC just PM'd me today saying his mechanic told him he needs a new fuse box. May be a new fuse box that is improved in 2002 is not a permanent fix after all???
The burn mark is worse on the relay side. If the black mark on the wire means anything, then my guess is your relay generated the heat and sent it down to the fuse box. I don't see any evidence of fuse box (or what you called as after relay) generated the heat and sent it back up to the relay in these pictures.
The relay that I use in the kit that I am selling is rated for 40A, perhaps it generates less heat and has better thermal characteristic than your 20A OEM relay. I haven't seen problem like this from my kit.
Maybe the relay but I did install the newest relay from the dealer when I built the kit. As mentioned - I built quite a few of them and also alternated relays - same heat issue. Just problem solving but maybe it was the relay. The new fuse box came with a number of relays but NOT the EFI relay so I used the same one and zero heat or issues so I would rule out the relay.The burn mark is worse on the relay side. If the black mark on the wire means anything, then my guess is your relay generated the heat and sent it down to the fuse box. I don't see any evidence of fuse box (or what you called as after relay) generated the heat and sent it back up to the relay in these pictures.
the issue is downstream in the box and I will bet that once it starts to fail - it is just a matter of time and wire size and the jumper are not a permanent fix.
Based on my experience - the short is post relay and power to the ECU in the fuse box.
After seeing your pictures, I am sure you didn't have good voltage post relay. That is WHY you had low voltage to ECU and crank with no start. My experince on this is a small voltage drop is enough to cause it not to start.Look at the ROOT cause of the problem with the crank/no start - low voltage to the ECU. Why? If you have good voltage and continuity pre-fuse and post-relay - then it is in the box and that is the reason the ONLY permanent repair is to replace the fuse box.
It is very clear that your heat source is from the relay, not from downstream. If the relay is good then I would look into connection and wire size.Maybe the relay but I did install the newest relay from the dealer when I built the kit. As mentioned - I built quite a few of them and also alternated relays - same heat issue. Just problem solving but maybe it was the relay. The new fuse box came with a number of relays but NOT the EFI relay so I used the same one and zero heat or issues so I would rule out the relay.
I agree on the hotter part but not on the most AMPS part. Amperage/current remains constant in that path, resistance increases when there is bad connection or corrosion, more heat is generated with higher resistance from the same amount of current. Voltage drop increases with higher resistance too. Furthermore, higher temperature (from the heat) reduces the conductivity of the conductor, that means higher resistance from higher temperature. It goes downhill from there, higher resistance causes more heatThe most AMPS would put through the degrading bar/connection - the hotter it will get and the faster it will fail.
@LWA55DAL sorry if you posted this previously: What is the part # for the fuse box for '98-'02 UZJ100s?
