My immobilizer fix
I see what you mean. I believe this little Hella will work. Headed to the desert soon and want to have some thing in place in a few days. At the very least like you said a solidly connected wire between the positive battery terminal and F would get me home correct? Thanks.
HELLA 007794041 12V, 5 Pin, Mini ISO Relay with Diode Coil Suppression, Black https://www.amazon.com/dp/B003NDXN8C/?tag=ihco-20
Yes and yes.
Can you please post the immobilizer part number?
89780-60220 located way up against the firewall. Picture of it just to the right of the of the right duct after you pull out the center unit in the dash.
Yes, I am.
I think I need one as well. Does this basically ensure that I don't need the transponder or whatever disables the ignition? Trying to eliminate as many of these fail points on my LX as possible as I spend alot of time in the mountains
I would like purchase one of your kits as well please.
I just sent you a PM for one of your kits if still available.
Thank You.
The security light blinks while engine cranks. I'm going to jump A --> F tomorrow just to make sure. (Done! Confirmed start.)
