Builds My GCC Spec 1HD-FTE Converted FZJ100 (3 Viewers)
Just finished a 3,000 km trip through Washington. We gave the WABDR, section 2 (didn't make it to section 3) a try and it was quite an awesome route! Washington has some great country to explore, would love to go back.
Beautiful and inspirational, Nick! I have to ask, did anyone come up and ask about your truck and its Middle East go-faster stripes and factory rear spare? The OEM mount for spare in particular is really noticeable to anyone 'in the know'. Did anyone ask about the fact that it is diesel?
Funny you mention that. Literally ZERO people during my three trips to the US asked about my truck, and zero waves from oncoming cruisers. No one cared.
I get lots of questions at gas stations in Canada though!
Time for an update!
I figured I was long overdue for another upgrade... I have a recurring driveline vibration which I traced to my back axle. And since it is the only part that is untouched, I figured why not rebuild it and check it off the list.
I got myself an e-locked axle and decided to reuse/modify my current housing. The reason being that I actually really like my drum brake (the donor had rotors) especially with the manual trans. If I'm on a steep incline, I KNOW I can pull the e-brake and it'll hold position with the engine running.
I got new bearings, seals, flange and AISIN elocker. The 3rd member ended up looking really sharp.
My buddy Billy was able to help me cut a notch in my housing to accommodate the elocker. As far as I could tell from my research, that is the only difference in the housing. Well, plus slightly different length studs, which I bought new of course...
Cleaning the housing after cutting took a VERY long time. We spent ~3 hours just cleaning the internals of the housing to clear debris and old material from the previous diff. I think we got it pretty clean, though I'll still do a fluid flush after ~100km or so.
All in and installed! I have my axles out getting rebuilt at a shop with new bearings so those will go in very soon and hopefully the 100 will be smooth as butter... fingers crossed for the love of god fingers crossed.
Looks fantastic my friend!!!
@gnarlynick2072 where did you source the e-locker actuator? Can you remove one and reinstall one without taking the diff out or apart?
AISIN Actuators are available on Rockauto actually! Marginally cheaper than OEM but still way too expensive...
You can remove the actuator quite easily, but you need to remove the plate that holds the position switch first to remove the bolt on the actuator fork, then the actuator can come out.
H152F conversion and vibrations solved!
Well it’s been a while since I’ve updated this thread.
I’ve had minor to major driveline vibrations on this vehicle since I’ve owned it and it’s plagued me for years. The 3rd member install didn’t make a difference which was a bummer so I finally admitted defeat and took it to a shop for analysis. They put it on a hoist and ran the vehicle and said that my vibrations/noise was most likely coming from the transfer case.
So, I went on a journey and found the most cost effective option for a new replacement - an HF1A from the JDM spec GRJ76. Brand new OEM.
There are a few differences between the 100 transfer case and this one, notably the transfer shifter tower. It is cut too low and only 2 holes are tapped on the GRJ76 version.
So I took a big chance and got the tower cut on my old casing to act as a spacer on the new one.
And had my buddy help drill and tap new holes on the brand new transfer case.
And then the fun part.
I had originally bought a new H152F for my 80 series restoration but figured it wouldn’t be finished for quite a few years and might as well make my 100 a pleasant highway driver.
So we tore down both gearboxes on the benches.
And installed the necessary conversion components including the 1HD/1FZ input shaft, throw out bearing shaft and 1HD bell housing. It went quite smoothly! Only downside was we couldn’t reuse the nice shiny new casing as the 100 casings are completely different, so it’s somewhat of a sleeper gearbox.
And as always, it was a gigantic pain in the ass to install. No job is worse than installing a manual trans on the garage floor.
After all the work and installing the new transfer case I have to say that the driveline vibrations are gone!! It was so much smoother and the new 5th gear makes an unbelievable difference on the highway. It’s very pleasant. Not sure if anyone else has done this but one thing I noticed was that the H152 needed a bit of a break in period before it started shifting nicely.
Next job - redoing my spare battery system and new injectors!
