I found this 85 FJ 60 in Chicago, It was a 2 owner (13 years each). It was pretty well just driven & poorly maintained FJ. 2nd owner only fixed it when it broke down!! No service to speak of!!!! Maybe changed oil every so often!!!
I felt I must rescue it!!!!
The PO sold it because the clutch/pressure plate replacement was $1850.00 & was pissed at it!!! So it did have a good clutch!!
Items I have completed since I found it 3 months ago!!!!
1. Deluxe OME 2" medium lift from Manafree.
2. New brake system-calipers, rotors, pads, clips, springs, etc on from/Drums, shoes, wheel cyl, springs, etc for rear. Manafree
3. New wheel bearings on rear axles with rebuild gasket set. JT outfitters
4. Steering knuckle rebuild kit-JT outfitters
5. Front wheel bearing kit with all new gaskets-Jt Outfitters
6. New U joints in both driveshafts-Manafree
7. New tie rod/pitman rebuild-JT outfitters
8. New (used) Smitty bilt tube bumpers (front & rear)-Mud member
9. New Tube nerf bars-SOR
10. New deluxe carpet kit-SOR
11. New rear wheel well trim/electrical trim pieces-SOR
12. New Duck seat covers-SOR
13. Safari Snorkel-FJ62 owner
14. Changed all fluids/oils/greases/raditor flush-Midas
15. New power steering pump/gearbox combo-Autozone
16. New marine 1000 amp battery-Ranger boat dealer
17. New pioneer stereo system/speakers=Walmart
18. 2" frame mounted receiver hitch-Craigs list
19. 34"x9.5"x15" Super Swamper tires (narrow)-National Tire
20. Factory chrome wheels (used)-Craigs list
21. Fan belts-SOR
22. Muffler system/complete-Midas
23. Rear hatch struts-McMaster Carr
24. New plugs/wires/cap/rotor/fuel filter/air filter-JT outfitters
Items left to complete
25. New FJ60 Carb-American toyota INSTALLED
26. New radiator hoses/oil cooler hoses-American Toyota INSTALLED
27. Install rear hatch window with defroster-Mud member
28. Change out frame-Mud Member(although mine isn't to bad!!)
29. New Coil-American Toyota INSTALLED
30. New fuel pump-American Toyota INSTALLED
31. New emissions check valve (air rail), vacuum lines, emissions tubing-American Toyota & SOR INSTALLED
32. Replace tailgate/rear quarters/repair body rust/paint-parts from Mud members/SOR/local body shop
33. ARB roof rack-Iron pig
34. Trans/transfer bypass hose kit-Mud member/Manafree INSTALLED
35. Rest to be figured out!!
36. Batery Cables INSTALLED
37. Starter INSTALLED
I have attached before & after pics of the FJ 60!! I have made 4 road trips in it since most of work was completed!! 2035 mile trip to east coast, 240 mile in state trip, 455 mile trip to OH & back to IL, 615 mile trip to TN & back to IL.
Th Landcruiser runs straight down the road, stops great, rides smooth, very trustworthy road machine!!! Just thought I'd share my info!!!
21. Fan belts-SOR
