- Thread starter
- #41
Finally got around to replacing the alternator brushes, belts, and fusible link. All I can say is big hands in tight spots equals pain in the ass. Removed the battery, battery box, unbolted power steering res., and moved a few things out of the way so I could access the alternator. Replacing the brushes only took five minutes once alternator was removed and on the "very organized" work bench.
Once I figured out all the bolts to loosen, replaced all three belts, but had to remove skid plate and steering stabilizer to access the A/C belt from underneath. Fusible link went in with no problem. After putting everything back together, it started right up and was showing full charging around 14 volts according to the gauge.
Before, all the lights were lit up on the dash, now, only the CEL is on, but everything went smooth on the test drive. Will have to do some diagnostics to figure out why the one engine light is still on. My suspicion is it is either the AFM solder repair I did a few months ago or a worn wire on the oxygen sensor from where it touched the down pipe. Engine runs smooth and cranked right up after sitting for a couple of months.
Old verses new brushes. Definately time was up on the old one.
