gregnash
Anal Retentive Analyst
I have to admit that doing it is a little scary and frustrating. But start with the lines that you can figure out easiest (like the passenger side VCV). From there work on the stuff that connects around the carb. Once you start doing that it will all of a sudden "click" as to where things go. Really there are only a couple lines that go from one side of the engine to the other (both from the distributor to the carb almost directly). It took me about 4hrs straight to route everything and a couple of misrouted lines that I picked up after studying the documents.
One of the best pieces of advice I can give after doing this is that know where all the items, bolts, etc are. Know what you are removing and what will be staying and work slowly. I did mine over about 2 1/2 days starting on it late one Friday night just kinda getting things sorted, all day Saturday, and almost all day Sunday. Then Monday morning was spent checking and rechecking everything and doing some carb adjustments.
Also, couple good things you will need:
- fine tip sharpie (used to label things)
- painters tape (I used this to mark lines so I knew what was going where and did so on both ends)
- exacto knife with a nice sharp blade (this saved me from breaking any valuable nipples)
Then don't forget to go to the hardware store and grab:
- rubber nipples (they were the yellow ones at NAPA and were like $.99 ea)
- 3mm T fitting (this is used on the gas filter valve that is in the intake manifold)
That is a difficult one since you dont have the factory air cleaner and I am assuming you don't have the stock AISIN carb? I am pretty sure Klinetime has desmogged and is using a weber so maybe ask him or check his build thread.
Yes, used that one.
Just not clear what i should do with HIC valve as i am not using factory air cleaner housing.![]()
