How was it before w/ just the HAC advance tied to the secondary can???
The 3 HAC fittings on the carb are for 3 separate circuits. If they were all tee'd together, then connected to a VSV, at high altitude, they would work fine. All 3 would pull in extra air through the VSV as they needed it. But when the VSV was closed, the idle fitting would be sucking, and it would pull fuel in through the other 2 fittings. At higher speed, the primary main HAC fitting would suck fuel out of the secondary....
What is needed is a VSV that when off has 3 separated vac fittings, then when on connects all 3 to a common port (atmosphere). Or 3 separate VSV's powered by one switch.
Ok, I rerouted my vacuum to original, ported primary on carb to primary on dizzy, HAC to secondary on dizzy. Got a little knock so I retarded base timing 2 degrees. Then 3 degrees...knock went away. Now the idle is a little rough. Thoughts?
Could you use one VSV with a T to the three lines to the fittings, and then place one-way valves in each line? That way each line would draw in air, but wouldn't be able to draw fuel out from the other fittings?
Or, are the factory one-way valves not up to that type of a load?
At low altitude, the HAC valve port B is a leak, allowing the vaccum that's headed to the advancer to leak out through the HAC. The check valve keeps the leakage rate to a reasonable minimum, so not to upset low alt driveability.
See p.3-31 of emissions FSM.
