Here is what I use at work:
Lisle Corporation
Now there's a good solution. Be great to have something that works for both Toyotas and the Plymouth in my driveway. Good find, brother.
Lisle Corporation
It may also be worth getting the diesel filler neck (wide mouth option with no 90 degree bend) welded in to the petrol version radiator, this removes all of the problem as well.
Is your right front elevated? Heaters running? If so and you can't get any air out of it even squeezing the hose occasionally, then you're probably pretty close to 'burped'.I just tried this and I have a ques. after running the eng while the funnel was in it filled the funnel up about 3/4 of the way. I let the eng get to about 205 the upper rad hose was hot so i know the therm opened up. is this normal. I did not get any bubbles.
