moving up from an 80 to a 200
Drive a 200 and report back. They drive on trail like a *much* larger vehicle. And the Tundra feels even more massive. Despite how they measure up on paper.
Compared to the Yukon XL I just got rid of, my '21 Tundra drives like a midsize (it does have best in class turning radius and an extremely short, easy to see over front end), and my LX drives like a Rav4 on steroids. 😆
I haven't driven a 200 so I can't say for sure, but I question if this is actually the case? On paper the 200 is only marginally larger than the 80: same wheelbase, several inches longer and wider. It's not like the 80 has ideal off-road architecture either. They're both big heavy station wagons.
Also, most 80s don't have F/R lockers. I doubt an open-diff 80 would outwheel a 200 with ATRAC and crawl control. Even twin-locked 80s can struggle on slick surfaces where the ATRAC/crawl control might be more likely to "figure it out" in a newer vehicle. The vintage auto in the 80 also provides subpar engine compression for steep descents.
Finally, stock for stock, I'm not sure the solid axle on the 80 actually has more travel than the 200 series IFS. Furthermore, are the 80 series birfs really stronger than the 200 series CVs? In any case, the 200 series definitely has more power to hurt itself out on the trails if you don't use the throttle sparingly. (Just thinking out loud here; I'd be curious to hear the perspectives from those who've owned and wheeled both).
Don't get me wrong, I love the 80 series. It's a classic! But it can be hard to parse how much of the 80 series hype is actually based in fact vs. nostalgia.
My 80 was lightly built with 35's and a front bumper. It weighed 5280lbs with gas and driver according to the cat scale, almost perfectly balanced F/R. LX570 is a around 1000 lbs heavier with 35's, gas and driver, no bumpers, skids or sliders. I think that's significant.
I also think the relative size is a big factor at least for me. There are some trails around here I could barely squeeze my 80 through between the trees or rocks. I'm afraid to try it in the 200. It may be doable, but not without high stress and excellent spotting. Just the experience of fitting the 200 in the garage vs the 80 is a completely different. With the 200 in there, I can barely squeeze my body around to the far side to get things off the shelf etc. With the 80, I could freely walk around. When it comes to wheeling, this is going to depend a lot on the terrain, obviously. In the desert, size doesn't matter much. In tight trails with trees, it can be the difference between a fun trail ride and expensive body damage.
I can say that in my limited wheeling in the LX, the 80 does have a noticeable articulation advantage, but I didn't measure or anything to quantify. Just seat of the pants judgement. My 80 was set up with really soft springs and long shocks and the front axle moved quite a lot. With soft stock springs, I think the 80 is also set up to allow a lot of movement up front, the limiting factor being shock length. I'm going to do some long travel mods to the LX and see how it can be improved.
My 80 had F/R lockers and I had to use them at least a few times a year. I would always try to run an obstacle open and then lock after a few failed attempts. I have tried crawl control once and decided I'd rather slip and slide through an obstacle than listen to what sounds like the truck falling to pieces beneath me.
Didn't break any birfs or CV's in either yet :hillbilly:
I don't think it's hype/nostalgia. Watching others on the trail (jeeps mostly) and the line backs up with people getting stuck on that one tough shelf, then you come to the front of the line and just walk right up it, there's definitely something to it. The 80 is better off road than anything I've owned short of my '84 mini truck, but that thing was barely drivable on public roads.
Just this guy's $0.02 :)
Maybe @TeCKis300 can answer but i think LC200 has better articulation than LC80 due to KDSS/AHC. Unmodded of course…so Heckraiser may be right due to mods.
Hard to believe after seeing a bunch of both on trail. Then again, they were all likely modded suspensions. The solid front axle is a thing of beauty with situations that require the suspension to articulate without the body being all twisted up. Set up well, the front and rear suspensions articulate and the body stays relatively flat, instead of doing the lift the rear wheel like a dog peeing and make the driver feel like they are going to endo. There is one spot in a tough local trail that demonstrates this amazingly - large boulders between a ledge and a tree, where there is one line over the drop. I'll have to try to get some video this year. @JetSurfer I think you know the spot I'm talking about, slightly uphill from where we both get caught up in our wide 200 series, and I think you had some door damage last year or the year before.
This might be the spot?
This is dangerous I know, but I need some input from people who have made the switch.
I currently have a 96 80 series that I love, but I'm starting to see the limitations of the 80 series for the way I'm using it. I currently don't have the time or place for the wrenching the 80 needs at this age and I need something that can do long cross country trips easily and comfortably. while the 80 is close, the lack of power, small back seat and other things that come with an older vehicle have me thinking about taking the plunge into something newer. this got me started looking at lx570s (because they are cheaper) from around 2010.
so for those who have been in similar positions, did you like stepping up to the 200/570? what are things you miss about the 80/ older cruisers?
my ideal set up is roughly 2 inch lift (want to run 33s) arb bull bar, rear bumper/tire carrier, sliders and roof rack for canoe. I live In the midwest so there's nothing super fun close by so long trips are common. been thinking about trailers, but that's not a today problem.
im not a hard core off roader but I do want to do some trails out west, snow wheeling, and travel into northern Forrests.
and no, having both isn't in the cards currently.
thanks all
With long trips and "cheaper" as considerations, have you looked at a 4Runner of similar vintage? Even without modifications it would likely satisfy your needs and be significantly less expensive up front and at the pump than a 200 series.
I don't pay much attention to ramp scores - what are the stock 200 series Lc and Lx scores for comparison sake?
Somewhere around 680 for stock LC200 and 650 for LX570 I think. LC takes advantage of KDSS. LX takes advantage of thinner sway bars + AHC compensating for the thinner sways.
Don’t forget all that🤩 heavy chrome on the LX. It adds up.
I had a built '97. I drove it everywhere, including many of the most remote places in the US. Now I have a (little less built) '09. I fricken love it.
Things actually happen when you press the accelerator to the floor.
It is quiet, the seats are comfortable, and the steering is so much tighter. All this leads to significantly less driver fatigue on long trips.
I dig the soccer mom vibes. I've come to hate the overland/off road brawny look more than ever (4runners/Tacos with 16 pointless amber lights, every angry eyed Wrangler, most Broncos, all Raptors...). I like how the stock 200 makes almost zero effort to stand out, and I think it's hilarious considering underlying capability. Long live the Highlander XL! (Not to say the 80 was particularly offensive in this regard, just a general observation about car culture these days).
I think the traction control/vehicle stability is great in the snow. It's sort of impossible to get it to go sideways without disabling those. I could do donuts in the 80 on snow. This is not really what I want for multi-hour drives in poor conditions on the highway. I like the stability.
Crawl Control is sick. It sounds like a cat playing with one of those springy door stops. But it's also neat to just point the wheel and let it figure it out.
The secret electric cabin heater makes it heat up much faster on a cold morning.
And if I want a solid front axle, 5 speed, beautiful and classic 4x4, I drive my FJ62 daily :flipoff2:
Been watching the new beastly generation of factory off-roaders come out like TRX, Bronco Sasquatch, Colorado ZR2 Bison, and soon to be Raptor R and Bronco Raptor. Keen on how far they're pushing the limits of factory capability and suspension articulation. I have been keeping this tracker that's been buried in other threads. Thought it would deserve its own as I make another update for lots of '21 models including the new F150 Raptor w/37s that scored 537 RTI, and Bronco 2-door Sasquatch coming in at 648.
Really shows how well the 200-series continues to hold its own, for a design first delivered in '08, even against this new breed.
Would love to see how some modded 200s do. I think some simple extended travel shocks, 34s+, and lower offsets would put it into the 700+. Theory until we see some results in real life.
RTI Score Chart:
'18 Jeep Wrangler Unlimited Rubicon JLUR (bar off): 724
Jeep Wrangler Unlimited Rubicon JLUR (bar off): 718
'22 Jeep Wrangler Rubicon 4xe (bar off): 701
Jeep Wrangler Unlimited Rubicon JKUR (last gen, bar off): 687
'22 Jeep Wrangler Rubicon 392 (bar off): 684
'20 Toyota Land Cruiser Heritage Edition: 661
'21 Bronco 2-Door First Edition 35" Sasquatch (bar off): 648
'17 Toyota Land Cruiser: 647
'17 Lexus LX570 (AHC normal, 20" wheels): 645
'21 Ford Bronco First Ed (bar off): 618
'21 Ford Raptor: 618
Jeep Gladiator Rubicon (bar off): 607
'17 Ford Rapter Supercab: 603
'21 Ram 1500 TRX: 602
'93 Toyota Land Cruiser 80-series: 593
'16 Dodge Power Wagon: 589
'20 Lexus LX570 Sport w/chin spoiler (AHC high, 21" wheels): 588
'22 Ineos Grenadier: 585
'95 Land Rover Discovery: 588
'10 Toyota 4runner w/KDSS: 584
'94 Land Rover Defender 90: 580
'17 Land Rover LR4: 560
'22 Tacoma TRD Pro: 559
'22 Ford F-150 Tremor: 557
'21 Toyota 4Runner TRD Off-Road (w/KDSS): 555
'14 Ford Raptor: 551
'20 Power Wagon (w/ disconnecting sway): 538
'21 Ford Raptor w/37" tire package: 537
Mercedes G63 AMG (last gen): 534
Jeep Wrangler Unlimited Rubicon JLUR (bar on): 523
'21 Bronco 2-Door First Edition 35" Sasquatch (bar on): 522
'04 GX470 w/KDSS: 519
Jeep Wrangler Unlimited Rubicon JKUR (last gen, bar off): 518
'17 Land Rover Discovery: 516
'07 Toyota FJ Cruiser: 515
'22 Rivian R1T (Normal): 510
'18 Dodge Power Wagon: 510
Chevy Colorado ZR2 Bison: 501
'21 Ford Bronco First Ed (bar on): 498
Toyota Tacoma TRD Pro: 492
'21 Chevy Colorado ZR2: 489
'22 Rivian R1T (Rock Crawl Mode aka high): 488
'20 Land Rover Defender 110 SE: 486
'14 Toyota Tundra TRD Pro: 484
Jeep Gladiator Mojave: 476
Toyota Tacoma TRD Off-Road: 468
Jeep Gladiator Rubicon (bar on): 458
'17 Land Rover LR4 (high mode): 457
'22 Ford Ranger Tremor: 441
'20 F-250 Superduty Tremor: 436
'22 Tundra TRD Pro: 436
'22 Nissan Frontier Pro 4X: 435
'04 GX470 (no KDSS): 428
'15 Ford F150: 420
'14 Ram Power Wagon: 412
Chevy Colorado Z71 (air dam removed): 410
'19 Ram Rebel: 406
'17 Land Rover Discovery (high mode): 377
'11 Mercedes-Benz G-Class 300 CDI Professional: 376
'17 Nissan Armada: 362
'20 Sequoia TRD Pro: 351
'20 Rav4 TRD Off-Road: 308
IMO, off-road is many things. I don't doubt the 80-series modified, is a better extreme rock crawler.
Not everyone is crawling extreme technical obstacles, of which a modified 200-series is going to be quite capable on too. Comparing many dimensions and measurements, a well modified 200-series on 35s can wheel at the level of a Bronco Sasquatch, and broach potentially close to what a Bronco Raptor is capable of in some regards. While being a stronger payload and HD platform. That's well enough for me.
What the 200-series is going to do way way better than an 80-series, outside of the most extreme obstacles, is literally everything else. Where most of us spend 99% of the time unless the goal is to create a dedicated rock crawler. On-road, highway, overlanding tracks, high speed baja, towing, and comfort into pretty serious crawling - the 80-series is not even close in these more likely use cases.
thanks all
do plan on doing a lot of initial baseline maintenance. I bought a 2011 lx 570 with 140k miles on it. Everything seemed fine and working when I bought and used it but will list the things I needed to take care of after I bought it:
1. Flush all fluids (transmission, differentials, AHC), this takes quite some effort if you are DIY, unless you know a good shop.
2. Valley plate leak - I had to fix mine
3. Radiator cracks (although my year is not in the faulty radiator year/model, eventually at 150k miles, I have a small crack which I should take care off soon)
4. spark plugs, tires and brakes are considered regular baseline but points 1,2,3 are something you need to expect for 200 series with around that miles.
The radiator PSA thread with the year range got started back when even 2013s didn’t have enough mileage to crack, which explains the inaccurate initial year range in the title. But those 10-13, 15, 17… radiators will as well.
If a US market 200-series was built before late 2018 it WILL need a radiator somewhere before 150k, usually before 110 and sometimes as early as 80k. Anyone looking at an 08-early 18 200 that hasn’t already been swapped should plan for this repair.
