i have a motorcraft carb on my 40 right now and i am getting a weber in about a week or so from a friend......i am contemplating swapping the two and putting the weber on. just wanted to see what you all thought. many thanks!
TJDIV said:rumor has it they're basically the same thing.
SpaceGhost said:Waste of Money? Just different amounts........................
Whats wrong the carb you have? Which intake manifold are you running? If stock, maybe the adapter is leaking or cracked, a very common problem with the webers. Out of the box they have to be modified to seal correctly.
I'd keep the motorcraft if the weber is your only choice.
