For Sale Most recent 100 series prices
Let’s try this again, prior thread deleted, I assume they want to keep it clean, there was no explation given.
If you have sold a 100 series recently and want to share what you paid with details on truck this will be helpful for potential buyers currently looking.
This thread can be helpful for buyers looking to understand the market and different factors that come into play on pricing.
Please stay on topic!
I recently sold 2004 LX with 176k for 12,500. Truck was 9/10 on condition with full service records. Southern Vehicle no rust.
16 years between inspections in CA on that blue truck. 11k in the first year then nothing till this year.
Nothing else between a pre-purchase inspection in July 2022 and 2006 in Toyota’s records.
Vehicle history shows it listed at $50k on 2/13/23 with the same photos. I guess they thought $50k wasn’t enough.
VIN: JTEHT05J762089361
So I have my eyes set on a 2006 LX with 130k and a regular maintenance history, TX/OK vehicle without rust. It's blizzard pearl, my favorite color. All the seats are reupholstered.
Clean carfax. Timing belt and rear brakes just done. Water pump and CV boots in 2015 at 100k. Timing belt might also have been done at 80k, which is when the 90k service was performed according to Lexus service records. Didn't think to ask about spark plugs and don't see them in either the carfax or the Lexus records.
Seller asking 24k. I'd have to fly to go check it out in person, seller says it'll need a new valve cover gasket at some point because there's a small leak, and the steering wheel is slightly off center though the truck doesn't pull.
Goal would be to have this car for a long long time for cross country trips, but very light off-roading. Not planning on selling, already made that mistake once with my previous LX. I've been pretty set on 5-speed/VVTI which are harder to come by, at least for the two months I've been looking. But prices are through the roof and I'm wondering if the market will get any better, and even if it does, will it get much better for LC/LX.
Opinions?
Pretty much pulling the trigger on this thing. Maybe I'm a fool.
Some pictures:
The Lexus history:
6/22/2017 (109227 miles)
REPAIR NUMBER: 0803152
REPORTED BY: Westside Lexus
SERVICE: WORLD CLASS INSPT'S
DESCRIPTION: ~|~WORLD CLASS INSPECTION - PLEASE FIND AND REVIEW ATTACHED VEHICLE INSPECTION REPORT ~|~ATTACHED INSPECTION REPORT CONTAINS IMPORTANT INFORMATION ABOUT YOUR VEHICLE. ~|~FOR YOUR CONVENIENCE WE HAVE REGISTERED YOUR VEHICLE IN OUR AUTOMATED RECOGNITION SYSTEM. THIS WILL ALLOW US TO INSTANTLY IDENTIFY YOUR VEHICLE WHEN YOU ARRIVE IN THE SERVICE DEPT SO THAT WE MAY SERVE YOU MORE EFFICIENTLY. A DISCREET TAG HAS BEEN APPLIED
SERVICE: GENERATOR/STARTER/MTR-GAUGE
DESCRIPTION: ~|~CUSTOMER STATES THAT BATTERY LIGHT ON ~|~FOUND ALTERNATOR FAILED LOAD TEST - RECOMMEND TO REPLACE NEW ALTERNATOR ~|~ALTERNATOR, R&R 05/07 - COMPLETED
SERVICE: DECLINED RECOM SVC
DESCRIPTION: ~|~DECLINED RECOMMENDED SERVICE ~|~FOUND AFTERMARKET BATTERY FAILED LOAD TEST - RECOMMEND TO REPLACE NEW OEM BATTERY ~|~CUSTOMER DECLINED TO REPLACE NEW OEM BATTERY - CUSTOMER WILL TAKE VEHICLE TO AFTERMARKET BATTERY SHOP. NO WORK PERFORMED AT THIS TIME
6/21/2017 (109226 miles)
REPAIR NUMBER: 0803080
SERVICE: INSPECT AUTO TRANS & DIFFERENTIAL
DESCRIPTION: ~|~CUSTOMER STATES THAT VEHICLE MAKES HUMMING/WHINING SOUND WHEN IDLING ~|~FOUND TORQUE CONVERTER MAKING WHINING SOUND AND REAR MAIN ENGINE SEAL SEEPING - RECOMMEND TO REPLACE NEW TRANSMISSION AND RESEAL REAR MAIN ENGINE SEAL ~|~CUSTOMER DECLINED TO REPLACE NEW TRANSMISSION AND RESEAL REAR MAIN ENGINE SEAL - NO WORK PERFORMED AT THIS TIME
2/22/2017 (108103 miles)
REPAIR NUMBER: 0775438
SERVICE: DECLINED MAINT SVC
DESCRIPTION: ~|~DECLINED MAINTENANCE SERVICE ~|~FOUND VEHICLE PAST DUE FOR 105,000 MILE SERVICE - RECOMMEND TO PERFORM A 105,000 MILE SERVICE ~|~CUSTOMER DECLINED 105,000 MILE SERVICE - NO WORK PERFORMED AT THIS TIME
SERVICE: CURTAIN AIRBAG GX/LX
DESCRIPTION: ~|~SAFETY RECALL GLB. CERTAIN 2004-2006 GX470 AND 2003-2006 LX470 VEHICLES CURTAIN-SHIELD AIRBAG CONTROL MODULE. ~|~THE SUBJECT VEHICLES ARE EQUIPPED WITH SIDE CURTAIN-SHIELD AIRBAGS WHICH DEPLOY FROM THE ROOF RAILS IN THE EVENT OF CERTAIN TYPES OF CRASHES. DUE TO IMPROPER PROGRAMING IN THE AIRBAG CONTROL MODULE, THERE IS A POSSIBILITY THAT, UNDER CERTAIN SPECIFIC AND ~|~AN AUTHORIZED LEXUS DEALER WILL REPLACE THE AIRBAG CONTROL MODULE AT NO CHARGE - COMPLETED OP CODE CGG01C 2.1 HOURS WARRANTY
DESCRIPTION:
3/24/2015 (97072 miles)
REPAIR NUMBER: 0628486
SERVICE: FRONT WHEEL ALIGNMENT
DESCRIPTION: ~|~REQUESTED FOUR WHEEL ALIGNMENT ~|~REPLACED NEW STEERING RACK AND FRONT DRIVE AXLE BOOTS - SEE LINE 3 AND LINE 4 ~|~ALIGN FOUR WHEELS - COMPLETED
SERVICE: *AXLE DIAGNOSIS
DESCRIPTION: ~|~CUSTOMER REQUEST TO INSPECT CV BOOTS FOR LEAKS ~|~FOUND BOTH FRONT INNER AND OUTER C.V. BOOTS TORN AND LEAKING - RECOMMEND TO REPLACE BOTH NEW FRONT DRIVE AXLE CV BOOTS ~|~REPLACED BOTH NEW FRONT DRIVE AXLE C.V. BOOT KITS - COMPLETED LEXUS EXTRA CARE (800) 448-1505 [NICK] AUTHORIZATION #VSA3BW6883
SERVICE: STEERING WHL/MAIN SHAFT
DESCRIPTION: ~|~UPON INSPECTION - FOUND POWER STEERING RACK AND PINION LEAKING ~|~FOUND RACK AND PINION LEAKING FROM BOTH BELLOWS BOOTS. ~|~REPLACED POWER RACK AND PINION ASSEMBLY - COMPLETED LEXUS EXTRA CARE (800) 448-1505 [NICK] AUTHORIZATION #VSA3BW6883
SERVICE: WATER PUMP
DESCRIPTION: ~|~UPON INSPECTION - FOUND WATER PUMP LEAKING ~|~FOUND WATER PUMP LEAKING - RECOMMEND TO REPLACE NEW WATER PUMP ~|~REPLACED NEW WATER PUMP ASSEMBLY AND TOPPED OFF COOLANT - COMPLETED LEXUS EXTRA CARE (800) 448-1505 [NICK] AUTHORIZATION #VSA3BW6883
12/21/2012 (80874 miles)
REPAIR NUMBER: 0463200
SERVICE: OTHER NON-OEM ACCESSORY INSTALL/R&R
DESCRIPTION: ~|~INSTALL DVD CHANGER ~|~REPLACE CENTER CONSOLE N FRONT 2 SEATS ~|~INSTALL DVD CHANGER
10/22/2012 (80874 miles)
REPAIR NUMBER: 0460886
SERVICE: INSPECT BRAKE PADS & DISKS
DESCRIPTION: ~|~REPLACE FRONT BRAKE PADS RESURFACE FRONT BRAKE ROTORS ~|~COMPLETE E ~|~FRONT BRAKE JOB, INCLS. REFACING, W/O HARDWARE, R&R 03/07
SERVICE: *REAR BRAKE PADS
DESCRIPTION: ~|~REPLACE REAR BRAKE PADS RESURFACE REAR BRAKE ROTORS ~|~COMPLETE E ~|~REAR BRAKE JOB, INCLS. REFACING, W/O HARDWARE, R&R 98/07
10/21/2012 (80178 miles)
REPAIR NUMBER: 0460304
SERVICE: BATTERY
DESCRIPTION: ~|~C/S VEHICLE HARD STARTING/ REQUIRES JUMPSTART ~|~COMPLETE E ~|~BATTERY, R&R 98/07 US
DESCRIPTION: ~|~REQUESTED FOUR WHEEL ALIGNMENT ~|~COMPLETE ~|~ALIGN FOUR WHEELS ALL
SERVICE: 30000 MILE SERVICE NON WARRANTY
DESCRIPTION: ~|~CUSTOMER REQUESTS A 90K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~90K MILES OR 108 MONTHS
9/11/2012 (79651 miles)
REPAIR NUMBER: 0452633
SERVICE: STATE INSPECTION
DESCRIPTION: ~|~CUSTOMER REQUESTS 1 YEAR STATE INSPECTION VIR ~|~STATE REGULATIONS ~|~1 YEAR STATE INSPECTION ALL
2/27/2012 (73375 miles)
REPAIR NUMBER: 0981241
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~ ~|~COMPLETED W/ SERVICE FRONT AND REAR BRAKES AT 4MM, MAY NEED NEXT SERVICE. ALL ARE OK AT THIS TIME.
SERVICE: 65000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 65K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE 34PSI 8/32 TIRES 4MM FT & R BRKS ~|~65K MILES OR 78 MONTHS 5529/6388
8/25/2011 (67697 miles)
REPAIR NUMBER: 0946978
DESCRIPTION: ~|~CUSTOMER REQUESTS A 60K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~60K MILES OR 72 MONTHS
SERVICE: *FUEL INJT FLUSH W/S
DESCRIPTION: ~|~FUEL SYSTEM TUNE UP WITH SERVICE ~|~PREVENTATIVE MAINTENANCE RECOMMENDED BY TIME AND MILEAGE ~|~PERFORMED COMPLETE FUEL SYSTEM CLEAN & FLUSH TUNE UP. FLUSHED FUEL INJECTORS & FUEL LINES, CLEANED THROTTLE BODY ASSY, AND DECARBED ALL TOP ENGINE VALVES
SERVICE: ST/SHAFT SNAP RING
DESCRIPTION: ~|~SAFETY RECALL ALF ~|~LX470 STEERING SHAFT SNAP RING ~|~INSTALL NEW SNAP RING / OP 0523G1
2/18/2011 (61632 miles)
REPAIR NUMBER: 0911884
SERVICE: 55000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 55K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~55K MILES OR 66 MONTHS
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~ ~|~COMPLETE W/ SERVICE
SERVICE: MISC
DESCRIPTION: ~|~C/S RADAR DETECTOR NOT WORKING. CHECK FOR ON/OFF SWITCH NOTICED AFTER LEAVING FROM LAST VISIT ~|~REMOTE FOR K40 HAD TO AAAA BATTERIES ENERGIZER BRAND ~|~REPLACED BATTERIES W/ DURACELL BRAND BATTERIES, SYSTEM WORKS FINE NOW. ADVISE CUSTOMER IF REPLACING THE BATTERIES THEM SELFS, TO DO W/ DURACELL ONLY BATTERIES
7/28/2010 (56466 miles)
REPAIR NUMBER: 0873314
SERVICE: 50000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 50K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~50K MILES OR 60 MONTHS 34PSI 5-6/32 5-6MM FT & R BRKS
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~ ~|~COMPLETED W/SERVICE
12/27/2009 (50981 miles)
REPAIR NUMBER: 0831972
SERVICE: 40000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUEST A 45K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~45K MILES OR 54 MONTHS
DESCRIPTION: ~|~WORLD CLASS INSPECTION ~|~REC FUEL INJECTION FLUSH NEXT VISIT ~|~COMPLETED W/SERVICE
SERVICE: LOW TIRE INDICATOR
DESCRIPTION: ~|~C/S LOW TIRE WARNING LAMP IS ON ~|~SPARE TIRE AT 27 PSI ~|~SET TIRES TO 34 PSI
7/8/2009 (45681 miles)
REPAIR NUMBER: 0799433
DESCRIPTION: ~|~LEFT BUTTONS OF STEERING WHEEL HAS PIECE THAT FELL OFF AND WAS LOST. INSTALL SOP PART. ~|~BROKEN OFF, NO PARTS, NOT WARRANTY ~|~INSTALLED LEFTSIDE STEERING WHEEL BUTTON SWITCH
DESCRIPTION: ~|~CUSTOMER REQUESTS A 40K MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~PERFORMED 40K MILES OR 48 MONTHS SERVICE AT 45,000MI
SERVICE: LOANER CAR
DESCRIPTION: ~|~LOANER ~|~IN ORDER TO PROVIDE EXCELLENT SERVICE TO OUR CUSTOMERS, PLEASE RETURN YOUR LOANER CAR WITHIN 12 BUSINESS HOURS UPON NOTIFICATION OF YOUR VEHICLE BEING READY. ~|~SURCHARGE FOR LOANER VEHICLE
3/17/2009 (40204 miles)
REPAIR NUMBER: 0778281
SERVICE: 35000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 35K MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~35K MILES OR 42 MONTHS AT 35
SERVICE: LOANER CAR
DESCRIPTION: ~|~LOANER ~|~ ~|~SURCHARGE FOR LOANER VEHICLE
DESCRIPTION: ~|~CUSTOMER REQUESTS 1 YEAR STATE INSPECTION EXPD 2/9, INS IN GLOVE BOX ~|~STATE REGULATIONS ~|~1 YEAR STATE INSPECTION ALL
DESCRIPTION: ~|~C/S THERE IS A BUTTON THAT FELL OFF OF STEERING WHEEL. ~|~ ~|~CUSTOMER ADVISED NOT A WARRANTY MATTER W/OUT MISSING BUTTON TO TURN IN. SEE ESTIMATE FOR REPLACMENT OF LEFT BUTTON SWITCH FOR STEERING WHEEL.
SERVICE: WINDSHIELD WIPER/WASHER
DESCRIPTION: ~|~C/S REAR WIPER IS MAKING NOISE, SCREECHING,. PLEASE INSPECT. ALSO INSPECT FRONT. ~|~ ~|~REPLACED ALL THREE WIPER BLADE INSERTS
10/2/2008 (34648 miles)
REPAIR NUMBER: 0747684
DESCRIPTION: ~|~CUSTOMER REQUESTS A 30K MILE SERVICE ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~30K MILES OR 36 MONTHS AT 30 TIRES AT 7/32'S BRAKES AT 7MM
DESCRIPTION: ~|~C/S LOW TIRE WARNING LAMP IS ON ~|~SPARE TIRE LOW 26 PSI,ALSO R/FRONT TIRE HAD A NAIL ~|~SET TIRE PRESSURE TO 34PSI AND REPAIR TIRE
DESCRIPTION: ~|~PLEASE INSTALL A NEW TRAILER HITCH COVER. ~|~ ~|~INSTALLED TRAILER HITCH COVER. N/C
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH
8/6/2008 (31884 miles)
REPAIR NUMBER: 0736742
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: ~|~REPAIR AS PER ESTIMATE!! HOLD FOR INSURANCE ~|~BODY DAMAGE ~|~SEE ESTIMATE FOR DETAILS
5/7/2008 (29163 miles)
REPAIR NUMBER: 0720804
DESCRIPTION: ~|~PLEASE RESET MAINT REQ'D LAMP ~|~ ~|~DONE
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH ~|~ ~|~DONE
SERVICE: 25000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 25,000 MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~25K MILES OR 30 MONTHS AT 25 BRAKES 8MM IN FRONT, 9MM IN REAR. ALL TIRES AT 8/32NDS SEE REPORT CARD IF NEED. VEHICLE DUE FOR MAJOR 30K SERVICE NEXT VISIT.
2/21/2008 (26359 miles)
REPAIR NUMBER: 0706682
DESCRIPTION: ~|~CUSTOMER REQUESTS 1 YEAR STATE INSPECTION EXPS 2-8 ~|~STATE REGULATIONS ~|~1 YEAR STATE INSPECTION ALL
SERVICE: RADIO/CD PLAYER
DESCRIPTION: ~|~C/S DVD PLAYER DOESNT EJECT OR INSERT. CK. ~|~ ~|~ORDERED DVD/CD CHANGER ASSY
SERVICE: FRONT/REAR BODY
DESCRIPTION: ~|~C/S REAR TOW HITCH COVER FELL OFF DURING LAST WASH. PLEASE REPLACE. ~|~ ~|~MAKE READY TO INSTALL
SERVICE: NON-OEM RADAR DECTOR INSTALL/R&R
DESCRIPTION: ~|~C/S THE REMOTE CONTROL FOR RADAR SYSTEM HAS FALLEN OFF AND MISPLACED PLEASE CK W/ PARTS FOR REPLACEMENT. ~|~ ~|~REPLACED REMOTE. CUSTOMER GIVEN AT SERVICE DESK.
DESCRIPTION: ~|~C/S CENTER ASHTRAY COVER FELL OFF AND NEEDS TO BE SECURED. ~|~FT ASHTRAY ASSY STICKING AND CLOVER FELL OFF OF TRAY ASSY ~|~REPLACED ASH TRAY ASSY AND CLEANED DEBRIS LOCATED IN ASSY OP# 550991 0.2HRS T1-62 T2-83
12/18/2007 (23364 miles)
REPAIR NUMBER: 0694654
DESCRIPTION: ~|~PLEASE RESET MAINT REQ'D LAMP ~|~ ~|~COMPLETED.
SERVICE: AIR CONDITIONING
DESCRIPTION: ~|~C/S ONCE HEAT WAS ON, TOOK FOREVER TO COOL DOWN. PLEASE TEST ALL OPERATIONS TO DETERMINE IF ALL IS OK. ~|~ ~|~THE A/C SYSTEM IS OPERATING AS DESIGNED.
SERVICE: NAVIGATION COMPUTER
DESCRIPTION: ~|~CUSTOMER HAD SOME QUESTIONS ON NAVIGATION USE, PLEASE SEE IF PARTS HAS C/D OR DVD INSTRUCTIONAL. ~|~ ~|~PLACED THE INSTRUCTIONAL DVD FOR THE NAVIGATION SYSTEM ON THE FRONT PASSENGER'S SEAT.
DESCRIPTION: ~|~C/R TO REPLACE ALL WIPER INSERTS, FRONT AND BACK. ~|~ ~|~REPLACED ALL THREE WIPER REFILLS.
SERVICE: 20000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~CUSTOMER REQUESTS A 20,000 MILE SERVICE CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS OTHERWISE SPECIFIED INSPECT AND CLEAN BATTERY TERMINALS. INSPECT ENGINE AIR FILTER INSPECT BRAKE FLUID LEVEL ~|~INCLUDES FACTORY AND DEALER RECOMMENDED MAINTENANCE ~|~PERFORMED 20K SERVICE. FRONT & REAR BRAKES ARE AT 8MM. ALL TIRES ARE AT 8/32.
7/24/2007 (18196 miles)
REPAIR NUMBER: 0664944
DESCRIPTION: ~|~REPAIR PER ESTIMATE ~|~ ~|~REPAIRED PER ESTIMATE
7/11/2007 (17500 miles)
REPAIR NUMBER: 0664723
DESCRIPTION: ~|~PLEASE GET B/S EST ON REAR BUMPER DAMAGE L/R. ~|~SENT TO BODY SHOP. ~|~ESTIMATE IS ON FRONT SEAT.
SERVICE: MISC MAINT
DESCRIPTION: ~|~NO CAR WASH, DRIVE UP AS SOON AS FINISHED. ~|~ ~|~DONE
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: ~|~ ~|~ ~|~15K MILES OR 18 MONTHS 36PSI 10/32 9MM 8MM
1/8/2007 (11267 miles)
REPAIR NUMBER: 0632416
DESCRIPTION: ~|~C/S K-BAN RADAR NOT WORKING PROPERLY ~|~ ~|~REPLACE BATTERY IN RADAR
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH ~|~ ~|~OK
DESCRIPTION: ~|~RESET MAINT REQ LT ~|~ ~|~OK
SERVICE: OTHERS
DESCRIPTION: ~|~C/S WHEN FIRST ACCELERATING THERE IS A VERY FAINT HUMMING NOISE HEARD FROM DASH ~|~ ~|~NO ABNORMAL HUMMING NOISE HEARD ON ACCELERATING
DESCRIPTION: ~|~CHANGE ENGINE OIL AND FILTER. CHECK ALL FLUIDS CK PADS, ROTORS, LINES, HOSES, CALIPERS, & PARKING BRAKE. CK STEERING GEAR & LINKAGE, BALL JOINTS AND DUST COVERS. CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~10K MILES OR 12 MONTHS
6/20/2006 (5310 miles)
REPAIR NUMBER: 0598463
SERVICE: CP CARWASH
DESCRIPTION: ~|~COMPLIMENTARY CAR WASH ~|~ ~|~OPK
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: ~|~CHANGE ENGINE OIL AND FILTER. CHECK ALL FLUIDS CK PADS, ROTORS, LINES, HOSES, CALIPERS, & PARKING BRAKE. CK STEERING GEAR & LINKAGE, BALL JOINTS AND DUST COVERS. CK EXT LIGHTS, BODY, & CHASIS ROAD TEST VEHICLE. CHECK TIRE PRESSURE AND ROTATE TIRES UNLESS ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~5,000 MILE SERVICE PERFORMED
SERVICE: 1,000 MILE SERVICE
DESCRIPTION: ~|~LEXUS PERSONALIZED SETTINGS PROGRAM INSPECT AIR PRESSURE IN TIRES. ROAD TEST VEHICLE. ~|~ ~|~CHANGED SETTING PER CUSTOMER REQUEST ON SELECTION FORMS OP CODE 001030 .4
1/22/2006 (12 miles)
REPAIR NUMBER: 0156026
REPORTED BY: Lexus of Birmingham
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: ~|~PRE-DELIVERY INSPECTION ~|~ ~|~COMPLETED PRE-DELIVERY INSPECTION.
DESCRIPTION: ~|~INSTALL VEHICLE TAG & BOLT KIT. ~|~ ~|~INSTALLED VEHICLE TAG & BOLT KIT.
1/19/2006 (1 miles)
REPAIR NUMBER: 0156109
SERVICE: DETAIL
DESCRIPTION: ~|~DETAIL VEHICLE
TERMS AND CONDITIONS
Hi all. New member and long time lurker here. I'm looking for a 2003+ Land Cruiser for overlanding, offroading, and Home Depot runs. I found a 2004 LX470 about 3 hours away. It only has ~148K miles, interior is in good shape and it looks pretty good cosmetically. The tachometer is broken and the AHC has been deleted, though. And it does have a bit more rust on the undercarriage than I was hoping for (it spent most of its life in Maryland). Does this amount of rust look acceptable? Or should I keep looking? Price is $11.5K.
I've definitely seen much worse in the mid-Atlantic, and it's a better than most of the <$13K examples near me. But I plan to add a lift, add 33" tires, and likely upgrade the front bumper as well. I plan on keeping it for many (10+) years if possible. Don't know if this is a good starting point.
Thanks!
Thanks!
If you want to keep it for 10+ years I'd suggest paying more for less rust.
I agree, if you want 10+ you should be looking for next to no rust. Its a huge pita to deal with once it’s past what that truck shows. You’ll never clean the inside of the rails and will slowly rust from the inside out even with protection.
If possible I’d wait and save up more cash and try to increase your budget a bit more. If you can wrench take the sacrifice on other things like torn boots/timing/suspension refresh/etc.
@usedname Looks like a clean truck, tranny whine and RMS at that price point does seem rather high. Clean 100s are hard to find though.
What's RMS? Is tranny whine something specific to that MY?
Thank you. Yeah, that's fair. I've seen examples in this price range with very little rust, but they were higher mileage and I was beaten to them by other buyers. Just keeping an eye out for another one of those.
Right, that's actually a good point. I can wrench a bit, but rust/corrosion has always been my Achilles heel. Regardless of which Land Cruiser I buy, I will do some sort of rust prevention treatment just to avoid future headaches.
Also, I could spend more, but I also don't want to take something too expensive off-road. Like, I even considered early LX570s in the mid-$20k range, but I knew I'd be too worried about damaging it off-road. Still, if it's another couple thousand dollars to get something rust free, then it's probably worth it.
Thanks!
Looking for some advice on this one. Being sold by a small dealer somewhat nearby. For the price and the miles it seems pretty great, but to be honest I've spent much more time following the 80 market, so I'm not 100% sure.
2001 Land Cruiser 139K miles Price: $12,995
Description copypasted from the ad: (Low miles on this clean title Toyota Land Cruiser. Fully loaded with heated leather dual power seats, 3rd row seating, rear air, 6 disc CD player and cassette player stereo, moonroof, running boards, after market black wheels, tow package. Runs and drives great. 4x4 and V8 motor. Hard to find vehicle that will last a long time!)
I'm assuming this would be center locked after using Toyotas vin decoder, but I'm not certain of that. I plan to get in touch with the dealer, but just seeing whats here, I wondered if anyone would be willing to provide some input? If this is a fantastic deal, I'd likely jump on it ASAP.
Thanks in advance for any help.
Google Drive link attached with more photos.
Land Cruiser 2001 - Google Drive - https://drive.google.com/drive/folders/1tKpYKWkDUhl-owY1oT38XVQ-qMCgkaRk
What are everyone's thoughts on a very clean 99, decent amount of work in the last 12-18 months (head gaskets, cooling system, water pump) plus it's got a lift/method wheels/33s - BUT
  • it has 291k mi
  • it needs a ps rack
  • the previous owner (maybe, maybe not) hit something in the front of the TJM steel bumper so the bumper supports are a bit tweaked and it sits crooked. possibly also damaged the headlight as the passenger headlight is brand new. I am now curious if it has a steel bumper in front because of the impact.
  • it needs all new ball joints up front. they're all split.
Asking is $18.5k but the seller asked what my offer would be. Am in SoCal since the market is always a bit hotter here.
  • it has 291k mi
Way too much for the listed price. Expand your search radius and keep looking.
Thanks. I have CL set to a 250mi radius which gives me SoCal in its entirety plus Las Vegas and the Phoenix area.
Prices seem so skewed out this way though so it's hard to tell. I honestly wasn't even sure an offer made sense as with that amount of miles I'd feel way better at like 13 or 14k.
This is the truck in question. It does present really well until you get under it. Unsure why the previous owner spent so much money on it and didn't do the rack/ball joints. Some pics I took of the underside (which had a bit more surface rust than I've seen for local trucks)
