Morimoto X.Bar LED Light Bars
100% Made in the United States. Hand Built in Atlanta, GA
The automotive aftermarket is composed of one part performance, two parts customization & Individuality. The problem with the Light Bar niche: Despite the wide range of available options, nothing really stands out anymore. These days, you can drop $2000 on a big brand bar or spend $200 on eBay and end up with pretty much the same thing, give or take.
The Morimoto X.BAR is bound to change the game. Available as a dedicated spot light, a dedicated flood light, or a combination of the two, regardless how you spec yours: you will be rewarded with mind blowing intensity.
X.BAR Construction: LED Pods machined from 6061 aircraft aluminum, shot peened and anodized with a piano black finish. Back-plates: machined and anodized. Brackets: machined and anodized. Bling Ring Bezels machined and available in five different anodized colors. You won't find any cheap extruded housings, boring black powder coat paint, chromed plastic reflectors or stamped steel mounting brackets here.
X.BAR Performance: A model of efficiency; The 30" X.BAR Uses 15 LED's to produce 18000 Lumens while consuming only 150W of power. Some of the most popular comparable bars on the market use 60 LED's to produce around 17000 lumens while consuming 195W of power.
X..BAR Tech: Completely unique, patented free form optics. CREE XML LED's with proprietary voltage regulators that are surrounded by light weight thermally optimized heat sinks. Gold plated contacts offer perfect conductivity and will never corrode. 100% Engineered, made, and assembled in the USA.
X.BAR Looks: Priceless. (but if you compare head to head with our competitors, we're confident you'll still find their actual price worthwhile)
Expedition Lighting System is a exclusive dealer for the Morimoto X.Bar. We offer a 5 year warranty on all light bars.
Pricing:
X.Pod 1 - $75
X.Pod 2 - $125.00
X.Bar 10" - $290.00
X.Bar 20" $600.00
X.Bar 30" - $900.00
X.Bar 40" - $1,200.00
Release Date: March 1, 2014.
Expedition Lighting - Morimoto X.Bar
info@expeditionlighting.org
