Do you track you mpg and if so would you be willing to share that info?
You stated you like Amsoil so why not use it in the engine as-well?
I don't track MPG. I try to fuel with Top-tier fuel and get premium when the temps are below freezing (the only time I can see a performance difference at my altitude). The only thing that really seems to effect mileage is accelerator position. If I can I like to cruise at 2200 rpm for max mileage but more often then not I get my cost efficiency by trying to stay below a ticketable speed. When I was towing a 3500 lb trailer it had very little effect on mileage so anything else is not worth my effort.
I lube with a goal of longevity but tamper that with the knowledge that very few cruisers will be put out of service by lube failures.
Amsoil is too pricey for engine oil that I will replace spring and fall regardless of mileage and M1 at Walmart is a killer value. I run Toyota oil filters since they are real cheap at cruiserdan prices and have great features (o-ring, dust cap).
I feel good with Amsoil in the diffs, Tcase and transmission since they go so long without a change. I do notice the difference on below zero starts.
If someone chose to run DexVI in the trans they might be doing better than I am. It'd be a great experiment for the board.
