Now sold.
Asking $350 local pick up in Twin Cities, MN.
Feb 2 update: I've cut off the side rails and weighed the pieces.
Rear beam with the tire carrier is 97lb, and the basket side alone is 57lb (plus a few more if you want bolts/nuts/shackle).
Greyhound is $157 for two pieces totaling 160lb terminal to terminal for most of the country
Here is the terminal locator:
Terminal Locator
MN - 4Plus FJ40 Rear Dual Swing Out Carrier w/ Tire & Basket with hitch receiver. Custom side rails added that mount to the frame (coming off a troopy, so 40 owners have to remove/shorten side rails to fit).
Side note: I am also replacing this rear '80-'84 frame member that is pre-drilled with the holes to mount the carrier, so that is available as well.
Older version of the current $1595 4Plus rear carrier offering
4PlusProducts | FJ40 | Tire Carriers | Rear Tow Bumper with Tire and Cooler Carrier
Terminal Locator
