- Vehicle Model
- 70 Series
- Location
- Rockford, MN 55373 United States
This is an advanced feeler posting for a 2L-T from an ‘87 LJ70 I may be getting soon. Looking at probably mid April at the earliest for when it would be available. Would be looking to sell as I have decided to go with an engine swap if things work out.
LJ70 was acquired non-running from an estate. Some effort was put into getting it running to find out after getting it running that the rings are shot. The engine reportedly does run, but it has blowby. At a minimum it needs a ring job. I can not guarantee the condition of the head as it has not been pulled, but there were no obvious signs of a cracked head after it was running. Timing belt and tensioners were done, injectors were inspected and cleaned by a diesel shop, as was the injection pump.
Included is an extra injection pump that was also inspected and cleaned, as well as a few boxes of miscellaneous extra parts and anything on the rig I do not need for my swap. I will also include the bellhousing as I will not need it with the swap I am doing, so this engine should be able to bolt up to any r150f/r151f you may have.
$2,000 OBO, not looking to ship at this time but may consider if it sits long enough.
