Jealous!
How many years did it take you to become as arrogant as you are?
Even a low reving diesel can create enough exhaust volume that a sufficiently small turbine housing can become an exhaust restriction.
Some people can read and learn.
Some people can be told and learn.
Some have to pee on the electric fence for themselves.
Yes, but a wastegates can only bypass that to cap boost, it cannot change the operating pressures. If you want to run at lower manifold pressures you need a larger A/R housing.
This is why variable geometry turbines were invented. Because wastegated housings cannot in any way mimick changing the A/R ratio of a turbine housing.
Porting wastegates is a waste of time. You can listen to me or you can measure your manifold pressures before and after (pee on the electric fence for yourself). It's your free time. Try it and get back to us.
I never stated anything contrary. My point, if you actually cared to know, was when you exceed the flow capacity of the wastegate. Exh Manifold pressure increases, boost exceeds the target, and you can overspin the turbine past it's design characteristics. This is when a larger wastegate is needed, not before.
It is a fairly close minded statement to make that there is no benefit to porting a wastegate on a diesel. While the same rules of thumb don't apply as do gassers, there are tremendous benefits to a higher flowing more efficient wastegate. Reduced manifold backpressures when using small turbine wheels at high flow, reduced EGTs as a result, and better overall efficiency.
Dougal said:You claimed lower manifold pressures, lower egt's and better overall efficiency. All of which are impossible to acheive by playing with wastegates.
The only way is to change the A/R of the housing. Here is exactly what you wrote:
Boost creep from exceeding the flow capacity of the fully open wastegate is something I have never seen on a diesel. This is why I suggested unhooking the actuator and going for a drive.
With 15psi max your wastegate isn't a problem and neither is turbo overspeed.
If you want to use labels like "arrogant", "close minded" and the like, it's best to understand the topic first.
Dougal:
Which method did you use to come to your conclusions - Read, listen, or the electric fence?
I was going to say something like: "Looks great SuperHatch, you have been doing you research, and diving right in.
I'd love to see a pic of the rig sporting thirty sevens"
Please put this to drama to rest gentlemen, you are both tremendous sources of tech and inspiration to the rest of us. Thank you for sharing your experiences and knowledge.
Let us know how she drives once you check for leaks.
Cheers,
The biggest single difference between petrol and diesel turbocharging is the exhaust temperature. Diesels have to run smaller turbine housings for the same compressor size and the wastegate on a diesel is only open at near full rpm and full load. Even then it doesn't need to open much to regulate boost. The rest of the time it's clamped shut so there's nothing to be gained by playing with it.
I'm running my 4BD1T with no wastegate actuator.
The wastegate porting myth is unfortunately quite well entrenched on the internet. Despite the complete lack of supporting evidence.
SuperHatch:
Don't let Dougal discourage you. I think you should go ahead and **** on the electric fence. Be sure to post up the results. Video would be good
Dougal:
Understood...
Why is there are difference between gassers and diesels as to what a "safe" EGT is? Both engines typically have AL pistons and both have piston cooling jets. The diesels have larger sturdier pistons with a greater thermal mass, so why does it seem that 1200-1300* is the upper safe limit on a diesel and some gassers will say that 1600* is ok?
My assumption is because the diesels are usually at load for much longer periods of time than a car...
