Mikita 4 1/2 inch grinder deal
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Today only $39
Makita 9557NB Factory Reconditioned 4-1/2-inch Angle Grinder | One Hot Tool Deal Every Day at Tooliday!
With a powerful 7.5-amp motor and 10,000 RPM, the Makita 9557NBR Factory reconditioned 9557NB 4-1/2-Inch Angle Grinder is designed for tough jobsite conditions. The 9557NB is also deisgned for comfort, with a small circumference barrel grip that is easy to handle for decreased fatigue. Along with performance and comfort, this Angle Grinder is also extremely durable — labyrinth construction and zig-zag varnish protects the motor and bearings from harmful dirt and debris.
Features:
Small circumference barrel grip (only 2.5 inches) for added comfort
Protective zig-zig varnish seals motor from contaminants by forming a barrier under rotation
Labyrinth construction seals and protects the motor and bearings from dust and debris by creating a complex set of channels
7.5-amp motor designed for high-output power in a more compact tool
Thicker coil wires are wound more closely to reduce heat and energy loss
All ball bearing design and metal gear housing for durability
Rotatable gear housing rotates 9 degrees for cutting applications
AC/DC switch for use with alternative power sources
What's In The Box:
Makita 9557NBR 4-1/2-Inch Angle Grinder
4-1/2-Inch Grinding Wheel
Wheel Guard
Lock Nut
Lock Nut Wrench
Side Handle
Inner Flange
Site bookmarked.
