Been running beadlocks for a few decades. Zero issues.
I have 2 sets of Trailreadys, 1 set of Racelines, 1 set of Allied, 1 set of Methods Run them at high pressures, low pressures, on street and trail, and beaten them all across baja and S. West. I use anti-seize on all of the bolts. I also have thick bead specific rings OR spacers to use. All my tires are Thick bead. Toyo MT, Pitbull, and Mickey Thompson.
directly off Trailready website--
Step4. InstallingtheClampRing.
With the pocketed holes facing away from the tire, index the valve stem relief to the valve stem and center all the clamp holes over the wheel bolt flange holes. Using a cross hatch pattern, tighten all bolts, in steps a few ft.lbs. at a time, working your way around the clamp until 20 ft.lbs. is achieved. Depending on the thickness of the bead on your tire, you should have no gap or an even gap between the wheel bolt flange and the back of the clamp ring **
It is normal for the clamp to distort into a slight cone shape when properly tightened. DO NOT EXCEED 20 FT.LBS ON THE BEADLOCK BOLTS. DO NOT ALLOW THE END OF THE STARTER BOLTS OR BEADLOCK BOLTS TO DRIVE INTO THE WHEEL. THIS WILL VOID YOUR WARRANTY, AND CAN DAMAGE THE WHEEL
** If the thickness of the tire bead, at 20 lbs ft., leaves a gap between the rim and ring, you will have an improper assembly, the result of which is potentially going to fatigue the bolts over a period of time and cause them to break. We offer 3/16” spacers to correct this problem.
Method Race Wheel Bedlock guidlines-
where they include a torque spec. chart for G8 hardware with and without anti-sieze
where they clearly mention a spacer to properly fit thick beads---
"MAKE SURE TIRE BEAD SEATS EVENLY TO OUTSIDE FLANGE OF WHEEL.
-A BEADLOCK RING SPACER MAY BE REQUIRED FOR LARGER TIRES. PLEASE CALL TO CONFIRM FITMENT PRIOR TO ASSEMBLY."
and... so everyone is covered. Racelines install instructions. Which also include a video and diagram and instructions to clarify spacer requirements and torque specs.
*Be sure install a valve stem before mounting tire onto the wheel
racelinewheels.com
I know. Im a man too. Hate reading and having to follow instructions!!!!
