Meat builds a 40
Lancaster, CA
Hi everyone,
Yup, you guessed it...another 40 build. After reading so many outstanding builds by some very talented people I got inspired to post what I've been up to since I came down with this disease we all call Land Cruisers. I've always been fond of Land Cruisers starting with the 80 series in the mid 90's. But, being a young dude in my 20's with a very limited income I knew it would be a long time before I ever owned something like that. Fast forward to 2013 and I'm now a high school math teacher/coach and I finally have the means to get a cruiser. I make the plunge and get myself a 1979 FJ40 from Colorado...I live in SoCal.
Sadly, I didn't realize what crappy smog laws (it had a SBC 350) we have here in California so my dream cruiser became an issue getting it registered. I found a "guy" to help me out with that, but I didn't want to deal with the every 2 years so I painfully sold her to a gentleman in Florida.
Shorty after that I came a across an add on Craigslist for a guy selling his 70 (running) and 72 (not even close to running) that lived very close to me. I went out to take a look at the 72 since it was the cheaper one and had the hardtop. When I got there I immediately became interested in both of them and took them off of his hands. My intention was to refurbish the hard top from the 72 and put it on the running 70 and then build the 72 the way I want it. I ended up getting that done (and I'll never do that again!) and I now refer to the 70 as Tweety Bird.
The 72 has very little rust on the body and the frame is great shape. I slowly started taking her (no name yet) apart and got it down to the frame. I had the frame sand blasted just last week and brought it back home. I didn't get it powder coated just yet since I want to box the frame and there are motor mounts/cross member to weld in....I'm trying to post some pics, but for some reason it won't let me at the moment.
My plan is this:
5.3 Vortec
4L60E tranny
Air Conditioning
Keep it a soft top
4" lift
Disc brakes all the way around
It was baby blue (maybe Capri) but I like the desert sand color
33" tires/wheels
and god knows what else!
My name is Craig and I hope to post as much I can as I move along with this project. As they say, it takes a village to raise a child, and when it comes to most of the issues I'm going to run across I have about as much knowledge as a child and I'll need as much help/input as you guys can give!
thanx,
Craig
Ok, think I figured out the pictures.
When you get ready for the 5.3, I can provide motor mounts and adapters, but in the mean time send me your snail mail address for a freebie V8 installation instruction manual.
Jim,
I actually spoke with you last week and you sent me your conversion manual....thank you! And, I'll be getting the adapters from you once I get to that stage.
Craig
I figured I'd start with rebuilding the axles so I began breaking down the front one first. My plan all along is to put disc breaks on all four corners and I was thinking of going with MAF's conversion kit or JTO's, but I heard that JTO is to stay away from? Why is that I wonder?
It's been suggested from many others on here to go with Poser's rear disc brake kit, so I hit him up and it's on the way as I write this. When I asked him his thoughts on a front brake kit he suggested I stay with Toyota parts and go from there. Well, it just so happens that I have a 79 front axle assembly so I'm going to use the parts from that one....I just have to do some grinding to fit the bigger birf.
Before I begin putting this axle back together I planned on putting POR 15 on it. Thoughts?
I have the 4 wheel disc brake kit from JTO. It uses GM calipers, rotors and pads so parts will not be a problem. The brakes work well and I am satisfied with the parts. Also use a Wilwood master cylinder from MAF.
I've seen mixed reviews on JTO's kit, but I'm not going to do any serious crawling or anything like that...just some trails here or there. Part of me doesn't want to take that 79 assembly apart since it's on another rolling chassis that I have.
Ok, it's been awhile since I posted to this thread. As many of you know life gets in the way of our projects. I'm a high school football coach and when the fall comes around I don't get much time to work on cruiser projects. But, I was able to get both axles pretty much "rebuilt" and equipped them both with disc brakes. A big thank you to Poser and his rear disc set up...awesome!
Hey everyone,
It's now the end of Feb and I have some updates:
1/18/17 I had to cut a massive hole in the floor board to fit the body correctly. I cut out the old floor where the gas tank was. Also, I cut across the width of the truck behind the tranny hump. My buddy Danny has helped me fabricate a new "removable hump". It's almost done, but I'm still not sure on what type of fasteners to use on the new part of the hump.
I got a little ahead of myself with the hole in the floor. Here are some pics of the frame after boxing and of the drive train installed.
The radiator mount proved to be quite a challenge. I tried to use as much as the original one as possible, but as you can see some of it had to go. I also made some arms to go with it as well.
Man, each thing on this project turns into a little project of its own. I'm learning a ton and having a blast. The steering also didn't go as planned so I had to make my own firewall mount for the steering column.
Looks about like what I'll have to do on my steering for my 1973. Been a while, are you still going on this?
I'm actually almost done with it...but, I've been lazy about posting updates....lol. I'll try and get some on here later today. This may help with your 73 steering. I didn't find this plate until after I had made mine:
Cruiser Outfitters
