Abrams M1 way too heavy - need something lighter like the Oshkosh M-ATV...
Oshkosh Tactical Wheeled Trailer video
That video shows it going over a few bumps, just from that, I would much rather take my cruiser in there than that thing.
Im totally in what way we go in , getting the front and rear outputs on the T-case done . The rear is good , but those fronts loosen up regularly. found a good front D-shaft with good splines. Looking forward to getting some use out of this thing
I think that the rear bearing per-load on those split cases should be checked every 24,000 km or maybe 48,000 km. If they are loose they 'wobble' and stress out the front as well as the rear bearing and races.
My rears are rock steady, its that dam front,
I am going to save some money so I can replace that crappy split case, Time for an ORION 4 speed, I use my cruiser but I dont abuse it , and these parts are completely worn out at 147,000 km , How can parts that are well greased and lubricated wear out, that is BULL****!QUOTE]
Aaron, I suspect your odometer is lying to you! Once you have the front axle apart, there may be some telling evidence. Don't listen to Glenn, you can install an Atlas if you really want to. Just takes enough $$$. To help finance your new project I'd be willing to buy your worn out T-case with the Marks gears for a negotiated amount. Let me know!
