Matt's 1997 fzj80 "Build" thread
I'm heading to Woodlawn fer some wrenching this evening. Should I come and rescue you on my way?
It'll be like 6...
You back home? forgot to check on you when I was up town
You need a Gorilla lug wrench with a short extension and 21 mm socket.
Or
A 60 series 2 piece lug wrench with an 18" section of pipe to serve as a breaker. This is what I carry in all my road-worthy Cruisers.
I think I have narrowed down the drivetrain whine (and worsening off-throttle grinding) to the rear driveshaft.(Just like Eric said)
I should have gone directly home from the last meeting two months ago (where Eric said it was the rear shaft) and checked the rear shaft.
Over the weekend I reinstalled the front and pulled the rear shaft to inspect the ujoints. The joints seemed ok, one was a little tight, but there is noticeable play in the slip joint. I am guessing that is where the off-throttle grinding noise was coming from. Also, it was installed 90 degrees out of phase, like the front shaft is supposed to be. After greasing everything and resetting the phase I re-installed it backwards so the slip joint splines would ride on the other side and it is quiet. No more 50 MPH+ whine and the grinding is completely gone.
I don't like the slip joint pointing down, but since it seems to be working for now I think I will run it.
ROH TAHDE.
Why flip it though? I bets it was the out of phase. But I also bet that slip yoke, if loose, is toast.
I need to refresh my U-Joints, all four of them. Maybe we should do a drive-shaft party?! Who's game?!
ROH TAHDE.
My original reason for flipping it was to just put the u-joints in a different spot to see if the sound changed. Once I found the play in the slip joint I figured it might help since the wear should be on the other side of the splines.
You are probably right that the phase probably was the issue. I will have to look back through my records buy I am pretty sure one of the joints was replaced by Toyota at some point.
I've always found it odd that cruisers run the rear shaft backwards anyway,
Rear U Joint was replaced by Toyota of Dallas sometime after the 200K mile mark...I hate dealerships.
I can't imagine it would last long dragging the slip joint over rocks.
Just looked it up and it was 210k. I remember now that that is the reason I ruled the rear shaft out from the start.
Here's a picture of your front bumper and winch being used in Telico many moons ago...they originated on wngrog's 96.
