Master switch replacement
Discussion in '80-Series Tech' started by zklebe, Jul 7, 2005.
  1. zklebe
    zklebe
    27
    Jan 29, 2004
    Has anyone on here had to place their Master Switch on the drivers door that operates the power windows ? Mine won't operate the drivers window or the rear right side passenger windo. Using the FSM I was able to confirm that the window motors both still function well. The RR passenger door has a plactic piece inside (worth about .05 cents) that is obviously worn out, but the drivers window switch look okay, I cleaned all the contacts in the switch but no luck, so I'm pretty sure the unit will need to replaced as well. How much will a new master switch cost or any other ideas on trying to salvage the old master switch. My LC is a 1996.
    Thanks
    Zach
  2. dfmorse
    dfmorse
    1,518
    2
    Jul 7, 2004
    EVERGREEN, CO, USA
  3. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    some people have had luck cleaning the contacts but that did not last long for me so I had to replace it, IIRC is was about $180, call CruiserDan
  4. LCphil
    LCphil
    115
    1
    Mar 14, 2005
    Alexandria, Virginia
    I actually have a spare second hand that I could sell you for a lot less if you can wait a couple weeks.
    I ordered new DS and PS switches to get auto up/down for both sides so the DS and the PS are fine.
    Let me know.
  5. zklebe
    zklebe
    27
    Jan 29, 2004
    some good luck
    Thanks for the offer on the spare parts, but luckily I finally cleaned the contacts well enough that the DS window switch is working perfectly. I will still have to replace the RR switch - but that won't be near as painful ($$$) as the master switch.
    A word of encouragement for anybody else that develops problems with the "master switch" on the drivers door - stick with it and clean those contacts as best you possibly can - the smallest amount of carbon build up will affect the operation of those switches.
    Zach
  6. SunTzuMD
    SunTzuMD
    612
    3
    May 9, 2004
    Ah ha! You mean I can swap out a switch and get auto down on the PS? Please tell me it's plug and play!
  7. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,078
    Mar 14, 2003
    Gig Harbor WA
    the master switch panel is about $150
    the door switchs are $30 or so each
  8. TX_TLC
    TX_TLC
    1,480
    9
    Apr 29, 2003
    Texas
    You can search and find how guys added this to their current switch...or maybe that was just auto up on the DS... :confused:
  9. LCphil
    LCphil
    115
    1
    Mar 14, 2005
    Yes Sirree 84810-32070 passenger side window switch $36.82 and 84820-35010 drivers master control switch $184.30. I haven't installed them yet - waiting for the truck to be returned from the body shop - but they both clearly have "Auto" on them. I hope the DS is both Auto up and down and the PS the same.
  10. LCphil
    LCphil
    115
    1
    Mar 14, 2005
    I replaced the master control panel and the PS switch with the Auto up/down switches I had ordered.
    They are not auto up/down much to my disappointment. I'm sure there is a Toyota part that the standard ones can be switched with for Auto up/down.
    I hope. Any ideas anyone?
  11. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    I looked into the auto switches from a 4 runner that have the asme pattern and external apearance as our switches except have auto for both DS and PS, problem is they use limit switches in the motors that the LC window motors do not have, our master switch instead watches for a curent rise of the motor and when it see it figures the motor has stalled and cuts off the power.
    this was discussed in more detail in another thread.
  12. LCphil
    LCphil
    115
    1
    Mar 14, 2005
    Thanks. I read the other thread but it was not entirely conclusive. It's a sad day when you can't get what you want.
