I think that this particular subject has been discussed in the past. I have a 1958 Toyopet that some of you have all ready seen at one of the shows. My master and clutch cylinders are mounted on the firewall side by side and they are a triangular in shape and I had them restored by White post in Virginia not cheap but the best once you get them back. I am having a problem with the clutch cylinder if I put the pedal to the floor the inside rod doesn't retract back soon enough and doesn't have any fluid inside if I remove the big nut . I suspect that the seals are not doing the job. Or how is the fluid traveling to the back side,is it through the small holes on the pistons. So I am looking for a pair of these seals if you know of anyone with an extra set. The body on both of mine are like a cast iron reservoir with a rubber cap and they are a triangular in shape I assume that the early 1960 style stout maybe the same. If someone could post a picture of the style that you have in your 1959 and later Land Cruisers so that I can see if it is the same as my 58 Toyopet.
Thanks
Frenchy
Thanks
Frenchy
