- Location
- United States
Please read the ad before contacting me for further information.
The truck as it sits has 184,234 miles, and I am the third owner. It's in fair shape and I am selling it as is, to be further fixed up and flipped/driven, or used as a project. Truck starts up first turn, idles great, doesn't leak anything, and drives. Interior and Body are in decent shape. Along with factory options, it has the factory rear E-Locker and rear heat.
Maintenance within the last year/15k miles:
-OEM Timing Belt
-OEM Water Pump
-OEM Serpentine Belt
-OEM Upper Radiator Hose + Clamps
-(1) OEM Fuel Line
-(1) OEM O2 Sensor
-(1) Exhaust Pipe Gasket
-Oil change every 5k using Mobil1 or AmsOil 5W-30 Synthetic
-OEM Spark Plugs
-OEM Air Filter
-Checked all Vacuum Hoses
-Cleaned Throttle Body and MAF Sensor
-OEM Radiator Cap
-OEM Heater Tees
-Front, Rear Differential, and Transfer Case Fluid swapped with AmsOil Synthetic, and Fill/Drain Plugs Replaced with Wits End S/S Hardware
Misc.:
-Removed Running Boards (believe I still have them)
-Removed 3rd Row Seats (in storage)
-Replaced Front/Rear Wipers
-Replaced Oil Drain Plug with a Fumoto Oil Drain Valve
-WeatherTech Front Mats
-Replaced Low Beams with HIR2 Bulbs
-Front Windows Tinted to 35%
-(4) New 285/75/16 Falken Wildpeak AT3Ws + 2 Valve Stems Replaced
-YotaMD Key Fob
Have several parts I haven't gotten around to replacing that will go with the truck to the new owner, unless I get around to installing them, I also have brief CarFax history, and I have documentation of when and at which mile each of the above was completed. Most work has been done by me.
Known Issues:
-CEL on for P0136 and P0156 (O2 Sensors) - Truck is Emissions Exempt in MA
-SRS Light on for Passenger Seatbelt Tensioner (IIRC) -Truck is exempt from this in MA
-Brake and Suspension work is necessary at some point
-Front D/S CV Axle leaking grease slightly
-Rust issues, the worst of which being the rear, and front sway bar mounts. The body and tailgate have zero to minimal rust, the only spot of concern would be where the rear wheel well/rocker panel meet on the passenger side
Title status as of today is lien. Serious buyers can discuss options with me.
Price now is $4,500, or best offer. I'm extremely reluctant to post this for sale, and I really don't want to, but circumstantially I have to. If you need more information or photos or want to discuss the truck ad nauseam, shoot me a PM.
Thanks
-OEM Timing Belt
-OEM Water Pump
-(1) OEM Fuel Line
-(1) OEM O2 Sensor
-OEM Spark Plugs
-OEM Air Filter
-OEM Radiator Cap
-OEM Heater Tees
Misc.:
-YotaMD Key Fob
Known Issues:
Thanks
