My drivers seat is frozen. Horizontal, vertical, and seatback tilt wont move. Unfortunately the seat is in a low position and the 2 philips screws of the protective plate cant be accessed. Is there a way to get the seat lifted manually so i can access these screws to remove the plate? Also how do I remove the seat adjustment switches on the side of the seat so i can test switches to troubleshoot my other adjustment issues?
i was able to bend the plastic shield back enough on the one side with the plastic worm gear plug to get the hex screws and other bolt off. The nylon gear in the housing was stripped. Is there the same gear on the motor side that needs replacing? If yes then the seat must be raised to gain access to the bolts
thank you for any help.
