Builds Mad Max - Another 60 on 80 (plus diesel goodness) (3 Viewers)
PLEASE post up your thoughts on the ABS after the install. I have been toying with the idea of installing the 80 series ABS into my 60 as well and youre the first person ive seen do it. Are you able to run it standalone with just the ABS Computer?
I'm running the whole 80-series harness with the un-needed circuits removed. It would certainly be possible to just remove the ABS system from an 80 and carefully pick out the ABS parts. I kind of don't think the system is worth the hassle... but... I'm in too deep, man.. I'm in too deep.
PDI includes some very rudimentary mounting brackets. I decided to make my own. I also opted to add some vibration isolators while I was at it. I got lucky when I picked up some A/C condenser mounting brackets on Amazon. They didn't suit my needs for the A/C condenser but the worked really well as intercooler brackets.
Labeled L and R. :)
Spacers needed. Whacked these up on the lathe.
To get the hole just right, I turned this bolt into a pointed stud and gave it a whack.
Welded the spacers onto the rears and done.
...I'm going to leave the tabs hanging down on the bottoms of these to zip tie winch wires, foglights... or whatever, way on down the road.
I still haven't figured out what the hell I'm going to do with the fan shroud. It's pretty much the last thing left on my engine compartment mock up checklist. Whenever I get completely gridlocked on a specific point, I tend to move on to something completely different.
And now for something completely different. One of the details I really wanted to get right are the warning lights... Since I'm using the 80-series harness and whatnot, I need most of the 80's original warning lights (plus those from a Landcruiser diesel, e.g. sedimenter, brake vacuum, and glow).
A little cluster rape yielded the needed parts:
After some 5th grade-level tinkercad youtube tutorials, I put my 5th grade cad skills to work. I've knocked up some prototype warning light holders which mate to the 62 cluster facia.
I need to tweak the finished product and probably have them professionally printed (once I figure out how to do a quadralateral....).
I'm still on the fence when it comes to the actual lights. I've got plenty protoboard and LEDs laying around. I may also try to make a factory bulb holder... I I need to figure out how to to be continued...
View attachment 3915181View attachment 3915182View attachment 3915184
View attachment 3915185View attachment 3915186
I'm still on the fence when it comes to the actual lights. I've got plenty protoboard and LEDs laying around. I may also try to make a factory bulb holder... to be continued...
Nice work, a little PCB and some light pipes or printed parts to prevent light bleed would work great
And, last but not least. I spent all morning knocking out this little doo-dad on a mill.
I made a 1.5mm and 2mm cable diameter mold.
Was hoping the end result would look something like this:
I tested it out with some lead free silver solder and had trouble getting it to drop to the bottom of the mold. But I hope to improve with some different materials.
View attachment 3915201View attachment 3915203View attachment 3915204
I tested it out with some lead free silver solder and had trouble getting it to drop to the bottom of the mold. But I hope to improve with some different materials. View attachment 3915214View attachment 3915215
Are you preheating your mold?
Damn i was hoping it might be worth the hassle to add even a little bit more safey to the 60 haha That was the plan, just pick out the essential parts from the 80 and stash them somewhere in the 60 dash somewhere
Dude if this is elementary level, my diff lock indicators that i made have got to be like toddler class at daycare hah. I didnt even think about robbing an 80 series cluster for their indicators
I'm experimenting. I really don't know what I'm doing but have plenty cable to play with til I find something that seems to work. From what I've seen on the web, everyone recommends packing the mold with flux then stuffing small snipped pieces of lead into the cavity. If I pre-heat the mold, I don't know how I'd get the flux in the mold.
How would you do it?
Maybe change the mold design so that it doesn't drop out the other side. Preheat the mold to ensure the alloy doesn't create voids. I think your alloy is cooling too quickly as it's being poured in. Look at old musket ball molds for inspiration. You may need to rotate your cylinder cavity and pour in from a sprue opposite where the cable is held in place. So in the example image below, your cable would be inserted into the nose of the bullet through a small hole in the bottom of the mold and your pour in from the top. Trim off the sprue once solidified.
This is some really really cool stuff.
Wins. I'm happy (for now) with the outcome from both experiments.
I will continue fussing with the warning light; I know I need to tone down the LED output just a bit and want to follow the contours of the factory dash facia openings a little better.
Also, I *think I figured out the trick to getting the solder to drop into the bottom of the mold. Basically I had to cold pack both sides of the mold with chunks of solder. I used a 4.5 mm punch and hammer to gently compress the silver solder into the void along with the flux. After applying heat for a period of time I noticed the lead began to drop/hop as the flux vaporized into gas and worked its way up and out.
I think the trick is to continue applying heat until the majority of that offgassing dissipates which probably means the lead has dropped to the bottom of the mold.
Badass thread. Good work!
