gregnash
Anal Retentive Analyst
So figured it would be better to start it's own thread here instead of clogging up @BenCC 3D Printing thread with back and forth.
For those that don't know, here is the link to the collaboration between @suprarx7nut and @BenCC M2V2 RAM Ball mount in the blank on the right side of the dash bezel opposite the Hazard and Center Diff Lock for our 100s. Here is mine mounted in Alita, my 1998 100 series LC.
Untitled by Greg Fisicaro, on Flickr
Likely, most of us will utilize this mount for navigation and comms in our rigs while on the trail or DD. For me both will be present for Alita so that I have quick and easy access instead of having a dash or windshield mounted arm like the iOttie unit I was previously using. The reason I wanted to get rid of the dash mount was simply because it was a bit in the way, causes slight damage to the dash and a bit of an eye sort to me. While I had one in my 60 when I had her (BeBe) it really is a bit different in the 100, don't ask me why, maybe symmetry or something but just feels "out of place". The solution provided by Ben and SupraRX7Nut is a perfect fix for me, once I get the appropriate attachments.
However, what I am finding is that while the RAM X-Grip phone mount is nice and seem quite stable, I just don't really like it due to the lack of one handed operation. The mechanism is stable and has a firm grip on the phone, but removing the phone is ... well not user-friendly. Add to that the fact that if you don't put the phone in the proper position relative to the upper arms (at least for my iPhone 8) you then end up pressing on the volume or power buttons. Enough vibration and you start setting things off, etc.
So I am seeing what people have and/or may use with this combination. This is for phone mounts that are compatible with 1" RAM Ball mounts. At this point I have found the following...
1. RAM X-Grip ~$27
2. TachForm Enduro Phone Mount ~$30
3. QuadLock Moto Ball Mount ~$30 - $60(for mount and Quadlock Phone case) **note: two different links here**
4. Hondo Garage Perfect Squeeze ~$85
5. RAM Quick-Grip ~$21
6. Arkon Mounting systems (multiple version like RoadVice, MegaGrip, etc.) Price varies by model.
7. 67Designs Universal Phone Mount ~$39
Anyone else have any others out there??
For references pic shows the RAM X-grip mounted to a 6" RAM double socket extension arm
I will be sending the extension arm back due to the fact that the adjustment is limited by the attachment to the ball. The way it is oriented in the pic is as far driver as it can go along with as far driver and straight as the X-Grip can go. I will be changing over to the RAM Dual Extension Arm mount. That mount should be here in a few days.
1. RAM X-Grip ~$27
