M2V2 Phone Mount thread....
Does anyone have any detailed pictures of how the parts secure the panel into the dash?
I‘m curious how solid the devices are once attached to longer arms.
you can swing by the house or we can meet in town and you can check out the one I have installed. I, too, installed a Quad Lock base on mine. Works well. I personally would be leery of hanging an IPad off of it. My dash trim is not securely locked in place. Looks like PO’s have been in the dash a few times
So on a 2000 LC are you snapping this piece of plastic off to get to the third screw hole there?
My 01 LX is exactly like this. I opted not to try and modify/mount anything there. Seems fine after a month of use holding a phablet.
I would do that however the rear section of the mount doesn’t sit completely flush that way,
I can’t find any instructions or anything online. I hate to guess before cutting something out, the third screw hole is there under there though.
I'd argue that sitting flush doesn't affect functionality however. They are rigid pieces.
Maybe a redesign for this issue could be warranted in the future, but for now I can vouch the intended functionality isn't compromised (coming from a guy who has designed and built mil-spec lasers that hang out of rotary-powered machines).
I can’t recommend this product enough for mounting your phone!
Ive been using X-Grips and RAM 1” hardware for years in my Tacoma and a PanaVice mount in the LC because that’s what the previous owner had.
Just a couple notes,
You need a small hand hack-saw, (or way to cut plastic)
3mm Allen wrench or adapter
T-8 Torx bit.
After you trim the small plastic piece that covers your 3rd screw hole, you can use the T-8 to install the three small T8 screws. They are counter sunk beautifully. Two of them have alignment tabs, just a genius design!
After that the (2) 3mm Allan screws will mount your RAM ball and sand-which it all together.
I chose to try the QuadLock, glad I did!
Thanks for a great product!
I am using a 4” RAM arm, the one that works with RAMs 1” balls abs the phone is a 6S plus.
T-8 Torx bit.
Awesome, thanks for sharing the install tips and for showing off some installed pics!
No video, but some extra pics that might be helpful. 2000 LX in my case.
Here's the backside of the main panel where the mount should sit with the small filler panel removed:
Backing plate won't sit flush due to that square tubular bit in the top right of the pic
Post-dremel wheel surgery, screw hole nicely exposed
Now it fits in nicely
All bolted up
Yup... just a few clips around it... Think there are three on the top and two on each side. I find it easier to start at the top on a corner then slide to the middle then go around one side then the other.
Yup. A plastic trim tool makes it cake, but any non marring thin object will work. Then disconnect the wiring plugs in the back and take to your favorite workbench.
After growing weary of some of the X-Grip flaws, I’ve temporarily swapped it out for a Slip Grip Kydex mount.
Advantages of the X-Grip:
  • Somewhat universal, phone model and case don’t matter (within reason).
  • Aesthetically pleasing w/ or w/o phone.
  • Holds the phone securely.
Disadvantages of the X-Grip:
  • Two handed operation.
  • Tends to press side buttons.
Advantages of Slip Grip:
  • Holds phone securely.
  • Doesn’t press side buttons.
  • One handed operation.
Disadvantages of Slip Grip:
  • Limited to specific phone & case
  • Not really beautiful w/o phone mounted
Good to see that so many people are posting up with their experiences with different phone mounts.
I am still running my quadlock (now on an iPhone 11Pro) and still loving it. Have been on some heavy wheeling trips and this thing is solid as a rock! Love the angle that it sits at for accessibility but still being out of the way when reaching for other buttons and functions on the dash.
@jLB - I too have grown tired of my x-grips. I’ve got 2 for sale. I stuck with the brand but moved to the one-handed quick grip.
Edit: added pic of Ram Quick Grip from my 80.
Been eyeing this for the new iPhones with MagSafe. Mounts to a standard AMPS plate. Wonder if it would be strong enough off road. I’m thinking it would be with the phone naked but a case may hinder the magnets just enough. Could use the Apple MagSafe case too I suppose...
I just installed mine tonight, and pretty darned pleased with it....
It seems that I've got the same X-Grip mount as everyone else. It seems to hold my phones fine, but it is a little fiddly two handed procedure.
Either I'm brilliant, or an idiot, but I liked the arm pointed down, where everyone else seems to have it pointed up...
Then again it is kind of warm where I am, and I don't want anything blocking my air flow!
How did you mount your ScanGuage to the coin drawer?
@CruiserGarage 's ash tray ScanGauge mount:
