Alright, who's gotta an LX in Oregon. Let's make this happen friends!
The photo with the red box is the Slee “custom LX slider” — can someone post more photos, reviews of the installed slider, if possible. Thank you.Reviving an old thread, please humor me.
It's been brought up before—but MetalTech claims their 200 sliders fit the LX570: Metal Tech 200 Series Land Cruiser/LX570 Sliders
I've never heard of any confirmed installs and assume they are mistaken.
Slee's custom LX sliders mount to the frame at 3 points. If the AHC armor were removed, would that back hanger on the MT's slide in under the globes (circled in red) in Slee's photo:
Yep, we need one. Until recently i don't think there was enough volume to warrant the traditional TLC fabricators to mess with the LX market. Now though, with 2008-2010 LXs in the low 20s and sometimes below, there is a pretty good interest in using the LX as an overland (and maybe more?) platform.Curious why aftermarket designers not just make a slider that would also serve as armor for the AHC that runs along the entire range of the slider. So a bolt on combination of skidplate and slider.
Look forward to seeing that come together.Yep, we need one. Until recently i don't think there was enough volume to warrant the traditional TLC fabricators to mess with the LX market. Now though, with 2008-2010 LXs in the low 20s and sometimes below, there is a pretty good interest in using the LX as an overland (and maybe more?) platform.
Agree on the need for skidplate deflection/protection for the AHC. And nobody has it. My current plan is to go with a local fab that makes kit sliders for ebay and get custom brackets made that replace the AHC rods with similar intraleg front to back skids. Even if it loses 1/4" or whatever of clearance for heavy plate it would be worth it.
If reasonable price and shipping could be worked out (~$500), I would buy one.Look forward to seeing that come together.
I agree regarding need for “penetration protection” — the AHC accumulators are rock solid, and mounting hardware is solid, but the “plumbing” (tubing between various components) is still 1/2 or so piping, and a limb that is thrust up there could definitely rip out or bend the piping. In my experience, it’s also a huge mud accumulator, and I had to pressure wash the mud several times just to get the AHC components clean.it is a recessed area for the most part, so it is penetration protection (pointy rocks or uneven limbs) I'm after. I don't need it to carry full weight, the rails should cover that. In thinking on it really an unlikely place to have contact, fairly narrow, protected an four sides. Maybe much fuss over not much risk.
Your knowledge of the AHC is impressive. A picture of what you think would work best would be very welcome.Being all the damping components are there, I would say it does need airflow to maintain performance when doing aggressive washboards for example. The valving components have heat sink areas built into them, so they do expect some airflow to dissipate heat. I suspect It wouldn't need much as it already has way more surface area and volume compared to just about any other suspension type.
From a slider design and geometry perspective, I believe it really needs an arm that cups under the stock frame rails to be able to translate the upward lever forces that pull up and out. Not sure if that translates with words, but maybe I can do a pic later.
Excellent and obvious idea, thanks.Yeah, you could just get some plastic sheet and metal zip tie it to the rods @lookinfwd21
