Ok. Staying tunedNot sure about the first scenario never really paid attention however yes at slow speeds over certain bumps the steering wheel moves. Truck is at the Indy currently getting checked out.
I'd highly encourage you guys to consider issue #4, as I mentioned earlier - the LCA bushings are pre-tensioned, when they should be relaxed at ride height.
I say this because you're getting toe-steer, but not in the common form when a suspension component is worn or has failed. (or it could be that the LCA bushings have failed, potentially prematurely due to it being tensioned). The symptom of the steering wheel moving dramatically reinforces this. Suspensions when working properly are highly engineering to resist toe-steer to the degree possible, and taking minor bumps generally shouldn't result in dramatic feedback to the steering wheel. (Unless offset is wrong but you guys are on stock wheels and tire sizes)
The pre-tensioned LCA bushing is getting further wound upon compression, and likely pulling the LCA out of alignment abnormally, resulting in both instability at the tire and feedback to the steering rack.
Two causes for pre-tensioned bushings
1) Suspension work, not following procedure and torquing suspension bushings at full droop on the hoist.
2) Alignment work with a frozen alignment bolt to the inner bushing race. Turning the bolt incrementally for alignment is all that's necessary to pre-load a bushing abnormally.
This might take some effort to diagnose as a tech will have to be convinced to look into this. It will require them to fully disengage the alignment bolt and perhaps remove the alignment eccentrics to know that the bolt is not frozen to the inner race.
sorry, wrong thread.
"Also found one of the tie rod nuts slightly loose. Says my camber bolts were seized so could not be adjusted"
What? The last place you went too never mentioned that. You need to move.![]()
So, after double checking, my tire pressures were at 38. I lowered them to 34 psi and the steering feels much better over bumps. I guess the LX is more sensitive to tire pressures than some other vehicles. I think with the new proper alignment and correct tire pressures the truck drives as it should.
34 cold (before driving on them)? What temperature was it outside when you set them? I want to try with mine tooSo, after double checking, my tire pressures were at 38. I lowered them to 34 psi and the steering feels much better over bumps. I guess the LX is more sensitive to tire pressures than some other vehicles. I think with the new proper alignment and correct tire pressures the truck drives as it should.
Tire pressures (i.e. Recommended Cold Tire Pressures) are not universal. If you want to know the RCTIP for your tires on your vehicle, just mention me @gaijin in your post and include your vehicle year and model (LX570 or LC200), tire brand and exact size and complete description - I'll give you the RCTIP for your particular setup.
HTH
P.S. RCTIP is set at ambient temperature. RCTIP is the same for 30 degrees or 130 degrees ambient. And yes, "cold" means the tires are equilibrated to ambient temperature and have not been driven on for at least 4 hours.
@gaijin how do you think the stock Cruiser suspension handles E rated tires?
Gaijin, wondering if you would still run KO2 tires on the oem 20" rim? Or is there a better tire?
It wasn’t 34 “cold” but I didn’t really have a choice it was midday and at night we are still in the 70/80s’ so temps don’t drop that much.
No haven't narrowed it down. The new tire size improved the condition but it is still there. Yet to try toe in the tires a little.It wasn’t 34 “cold” but I didn’t really have a choice it was midday and at night we are still in the 70/80s’ so temps don’t drop that much.
I am still experiencing the steering wheel play/twitch over small irregularities (but not large bumps). Feels like the wheels are fighting each other. I am beginning to think it’s the tires. (But I have the same tires on my wife’s 14 ML350 and they drive/ride perfect).
I’ve had it aligned at 2 different places and road forced balanced. No one noticed or mentioned any worn suspension items. But, if it was a suspension item, I would have felt this with the old Latitude Tour HP’s I just took off. Have you narrowed anything down? Don’t know if it’s worth my while complaining to Tirerack to get these Michelin Defenders swapped out for Bridgestones. But if I’m wrong, that’s just more time and money wasted.
Maybe since they just did your alignment take it back and ask them to play with toe and see if it helps?No haven't narrowed it down. The new tire size improved the condition but it is still there. Yet to try toe in the tires a little.
