LX570 lower dash switch panel? (2 Viewers)
I'd be happy to design something but I'd either need the desired components in hand or very detailed measurements and then you'd cover mailing test pieces for any tweaks. Parts in hand is definitely easier and faster.
For my LX, just drew up and printed this sunglass holder location auxbeam switch mount (still needs final tweaks and reprint in carbon fiber reinforced material) and some recessed cargo lights.
This looks really good.
Any chance the sunglasses holder is actually still usable for holding the sunnies? I'm one that actually religiously uses that but reckon that spot would be best for my switch panel. Keen to hear
Unfortunately, the actual sunglass holder function is removed due to the angle in which the switchplate mounts.
Maybe just me but the easiest spot to mount a button panel in the early model year LXs is the dead panel in the forward console. Nothing to build and print. Easy wire run. Good ergonomics and visibility - the latter of which is rather important to see status of lockers/lights/accessories. With storage space at a premium, I try not to the lose and factory nooks and cubbies.
Clean your replace your tip. Your filament might be too wet. I keep all mine in an air tight container with those moisture packets.
Also adjust your bed temp and nozzle temp to whatever the filament suggests.
I had the same problem and a combo of all of these fixed my problem
Thanks for this. Already replaced the tip/heater element. New filament too after new tip. All bed/tip temps where they should be. Still coming out dogsh*t. I’ve changed layer height and speed to. Still trash.
I don’t know how to run hdpe though it. But I’m told that should help. I remain frustrated.
No doubt that is a clean at up. I just prefer the look of OEM Toyota/Lexus switches vs an aftermarket set up.
I have a 2013 Chevy Silverado 2500hd with an older Amazon knock off 6 switch panel. It works great, hooking it up was easy but I just don't care for the look.
In all reality, if this panel doesn't become available in the next 3-6 months, this is what I'm going to do.
I'm planning on adding a roof rack. After that it's a winch then electrical. So we will see.
I agree if you are investing in switchpros, but if you are just looking to add OEM style switches and buttons (e.g., tow pro) it doesn’t work.
Hey folks, I’ve started working on the Switch Pros panel and have a favor to ask. Could anyone help measure the dimensions of the button panel and share some photos? I’m specifically looking for precise measurements of the back side—width, length, depth, corner radius, etc.
Is there a quick way to pull this cubby? Or is it pretty involved?
If it just pops right out, I can do it.
Or was it you or someone else who was waiting on another piece to model?
It’s not the hardest thing to get out. If you dig around in the fsm it has directions for it in the dash removal section.
My recollection gets more fuzzy everyday, but if I recall it’s the two pieces under the steering column, the piece on the side of the dash by the door, and maybe loosening the piece above it with the mirror controlling it.
All told maybe three or four little bolts?
A bunch of clips.
It’s entirely possible I posted up the relevant fsm section when I pulled mine out in my build thread
On that topic here’s the solution I ended up with.
Sorry folks, I didn’t explain it clearly earlier. I’m not looking for the back of the cubby—I’m actually looking for the dimensions of the Switch Pros button panel, measured from the back side (width, length, depth, corner radius, etc.). Appreciate the help!
Not sure if helpful but their website does have measurements
Also, holy crap sticker shock batman!
My thoughts exactly, which is why I am looking for an alternative mounting place for OEM type buttons (tow pro, starlink, etc.) to install in lieu of switchpros mount.
Samsies.
I have an older Amazon knock off in my 13 Silverado 2500hd that was $40 about 5 years ago. Its been absolutely fantastic. Its a gasser, but I put a second battery in it. I've got bumper lights, ditch lights, 12k warn winch and my air compressor all wired to it with the Amazon special.
I'd be down to put something like that in my 14 LX right in front of the ash tray if the 3d printed mount works. But I'm not sure if it does.
I can't seem to find the file or id test print.
I just put my Sherpa rack on my LX yesterday....so electrical is next
The onlyfeature I wish my Xmas gift knockoff switch thingy had is a dimmer. And the ability to hard turn it off, so I could run it on acc if I wanted.
I wired my Amazon special to a separate switch. I can cut everything on or off with the literal flip of a switch hahahahaha
Some of the newer ones have a master switch in the middle.
But yes they are bright af
Any update on this? Roof rack is on and light bar gets here Thursday. I'd love to start working stuff but I'll do an Amazon switch panel if I have to!
