LX570 AHC Globe/Accumulator Replacement (10 Viewers)
s***, should have bought a set earlier in the year. I'm pretty sure my accumulators are due. I've told myself from the beginning that if I ever need to spend much money on AHC, I'd delete and get a quality offroad suspension. But now that I've got my suspension a little more dialed in with the help of techstream and some parts, I was back to leaning towards keeping AHC and doing the accumulator service. I wish the seller could just advertise what the actual final cost will be. I've been reading in other threads that shipping companies (UPS, FedEx, DHL) are using the current situation as a money-grab and the extra shipping fee might not be 15% or whatever the tariff is. Added hassle of catching the customs bill and paying it on time before the parts are returned, etc. Maybe wait 3 years for a change in government? 😬
PLEASE HELP
I'm kind of at my wits end right now at this damn thing, and I feel like I'm not even to the hard part.
I watched the video, but I'm stuck at the part where you have to remove the bolts from that upper bracket in the middle of the globe guard that go horizontally into the side of the frame.
I do light work myself, but I'm not super mechanically inclined. I've been having a B***ch of a time with the limited amount of working space in that section. I have, on several occasions, considered committing war crimes against the engineers of this area of the truck.
On that upper bracket, I was able to get the lower bolt out, but I'm having trouble getting the top one. As the bolt comes out, there is no room for the tool. I even got a ratcheting box wrench like the video suggested, to get it out, but even that feels like it's scraping up against a line of some sort (maybe the hydraulic line?) which is frustrating, because I feel like the bolt is almost completely free.
What frustrates me even more is that I haven't seen anybody else mention this difficulty, which makes me think that there's something obvious that I'm missing.
My second question is that in the video? I don't think I remember seeing any washers. Was I supposed to buy new washers for the globes?
Any and all assistance would be greatly appreciated. Thanks guys!
I dont think the newer globes require them. Or at least, when I did mine, they weren't included, and I didn't buy them and it didn't cause any problems.
It's been a gazillion years but I believe I used a swivel socket instead of a ratcheting wrench to get up there. I promise they all come out. Good luck
PLEASE HELP
I forgot to mention that I considered removing the running boards bracket to give myself some more room, but then the top bolt of that bracket doesn't leave any room for a tool head to fit (the extension hits the globe guard, and the bracket shroud prevents my ratchet's head from moving). So I'm stuck there too.
If you can't tell, I'm just all sorts of frustrated. I've wasted two days on this project already (between toddler interruptions, and having to go back-and-forth to the store for different tools)
Yeah, I was able to get to it with a flex head, but by the time I backed the bolt out to a certain point, it's pinched up against some line/tube/pipe behind it. Maybe I just need to find something lower profile.
As I'm undoing all of these bolts, I also worry about how the heck I'm gonna get them back up there since my hands barely even fit up in there to line everything up. Thanks for the suggestion though, I appreciate it.
It’s been a while since I did this job, but can’t you also remove the bolts that hold the guards to the brackets? I vaguely remember thinking that a lot of the instructions had you removing more than what was necessary. It’s been so long since I’ve had the guards, I probably shouldn’t even post.
Thankfully, I was able to get them out with the ratcheting combo wrench, I was just worried that what I was using was going to get stuck in between (since the one that I have doesn't have a way for you to switch and tighten it back up, you have to pull the combo wrench off turn it around for it to go the other way).
If you don't mind me asking, how do you protect your globes with out the guards? Or did you convert to a conventional spring suspension?
Nothing as exciting as that, I have SLEE slider steps.
Thanks for the assistance everyone! In every challenge is a learning opportunity and I certainly learned a few things and picked up some new tools. After drilling the hole last night, I tried the pry bars I had and none fit so I ordered a new tapered pry bar. It was delivered today and I finally got the DF globe off! I got the other two globes off no problems and bled everything as directed. Below is the offending globe.
Hey jdo,
I'm in a similar type of bind. What type of pry bar did you go with? Also, how did you go about unscrewing it? Did you just slide the prybar all the way in and push against it in a counter-clockwise direction? I'm sorry for the stupid question. I've just never done this before, and I'm terrified of f-ing it up even worse. Thanks!
