LX470 Glass Headlight Lens Replacement (1 Viewer)
Charlotte, NC
My most recent project on my 2006 LX470 was to replace the yellowing and scratched polycarbonate lenses with glass lenses. From my understanding, the 1998-2002 LX470 came with glass headlights and in 2003, they switched to polycarbonate. I had a 2000 prior to this one and my wife had a 2000 4runner with glass lenses and it was so nice to not have the headlights age the vehicle.
I ordered glass lenses from eBay, see link below. They shipped from China and took about a month to get delivered. One showed up shattered unfortunately, but the seller was able to send out a replacement at no charge. The arrived within about 2 weeks.
Glass Lenses Link: A Pair For Lexus LX470 1998-2007 Front Headlight Clear Lens Housing + Seal Glue | eBay - https://www.ebay.com/itm/275754569788
Shipping box from china and glass lens unpacked
I had also decided to change out the corner light housings to clear side marker ones. I bought a cheap set off Aliexpress. This was a much worse buy. They ended up being substantially lower quality plastic Thant the OEM ones. They also didn’t really fit well. I wouldn’t recommend this. I kept my cracked OEM ones and will likely replace them with OEM corner housings in the future.
Corner Lights:
Don’t Buy: https://www.aliexpress.us/item/3256...2808573.1005001721675186&gatewayAdapt=glo2usa
Buy Instead: Front Clearance Lamp - 2006 Lexus LX470 - https://www.lexuspartsnow.com/parts-list/2006-lexus-lx470/electrical/front_clearance_lamp.html?pnc=81610L
In order to replace the headlight lenses, I removed the entire headlight housing. There are 4 10mm bolts that hold on the main housing. One bolt is hidden by a trim piece closest to the center of the front of the truck. There are multiple good videos of this on YouTube.
Once removed, I removed the 8 clips with a flat head screwdriver and 2 screws in the bottom center on the housing that holds the polycarbonate lenses in place. These 2 screws are not used with the glass lenses, all 8 clips will be reused. To melt the glue that seals the lens in place, I baked the housing in my oven at 200° (f) for 15-20 mins. (With a convection oven, I recommend flipping the headlight around halfway through) I baked it in a glass pan to prevent the plastic coming in contact with the metal grates as well.
Glass in back, old polycarbonate in front. Screw holes with screws removed shown.
Lenses were pretty easy to remove after that. With the lens out, I used the provided headlight sealant in the grooves. I found that stretching out the sealant to a thinner bead worked fine as I wasn’t able to remove much of the old sealant. I then baked the headlight housing with the new sealant bead for another 10 mins at the same temperature to soften the sealant prior to installing the new glass lens.
Installing the glass lens after the sealant was warmed up wasn’t too difficult. I would recommend using the clips to help compress the lens into the housing and ensuring a water tight fit. I was unable to get one of the clips on due to having too much sealant in a section and it hardening quicker than I could compress the lens on. I’ll edit this if I find it to ever become an issue.
Finally, reinstall the headlights, test the lights, and enjoy permanent non-yellowing lenses. (And add replacing those trim pieces to your to-do list that they are cracked like mine.)
Before (let) and after (right)
Please let me know if you have any questions. Hopefully this was helpful.
Thanks a ton for sharing! I didn't realize there were real options out there for replacement glass lenses.
It turned out great. Did you feel the fitment of the glass was as good as OEM?
Yeah, fitment is near perfect. I was very impressed with how well the glass lenses lined up in the housing and the glass even had little lips in the right spots for the clips.
I really really need to find a set of oem headlights PO replaced them with aftermarket unit and i really want to go back. Might have to buy some used poly carbonate ones and do what you did and order glass replacements
I replaced my bad polycarbonate lenses with new Glass Lenses i bought from Bell Lexus in Scottsdale. They worked beautifully in my 2006 LX470. I had them retrofitted with larger LED Projector Beams... Best modification ever! Unfortunately, I took some rock hits on the way back home to the SF Bay Area and experienced some damage. I was basically a day late, but ordered up and installed the thickest glass protection film I could find... WeatherTech LampGard. The film fit perfectly and went on easily... and so far, no further damage.
Ok so wait these glass lenses from Ebay fit in the housing meant for polycarbonate lenses? If so this is on my list along with maybe an HID kit.
I bought OEM Glass front headlights directly from a LEXUS Dealership. These are stock for the early years of the LX470 but they fit perfectly in the later years. Mine now sport the way brighter oversized LED projector beams.
Yup! Fits perfectly. Couple months later and I am still very happy with them. If only they sold glass corner lights as well...
Part#? I have a 2000 Landcruiser with rock chips in the glass headlights. I looked up the replacement and got 4 part numbers with no mention of which are glass.
About midway down. Lots of good info in that thread.
@gwilsterman - how are the chinese glass lenses holding up?? Did you apply PPF on them or running them bare?
@Zuberg @excessive Hey! The glass lenses are doing great so far. I have gone about 6k miles since the install and the look as good as new. I don't keep the LX in a garage and have been running them bare. I also have aftermarket LED bulbs in the housings. I am not sure if that matters.
I contacted multiple sellers with the same eBay ad for the glass and they all tell me it’s plastic..poly.. no glass. All pics for all sellers are the same.. they all look like poly
@ronnunan One lenses that I had originally shipped had shattered during shipping, definitely seemed like glass. Sellers replaced it really promptly and the lenses are still looking great today.
@gwilsterman The eBay ad you linked in the first post specifically says....
