LX470 AHC Accumulators (Updated with pressures & comments) (1 Viewer)
Sounds like either control valve assembly gate valves both closed. Which I suppose could be mechanical. But I'd think electrical more likely.
Or
Damping force control actuators, all 4 in max pressure setting. This could be a fault (short) in command to them.
So assuming good globes, pressures near spec., sensors working properly and at or near factory setting. I'd guess electrical.
Tech stream has utility where in, you can run test.
Or
Are the control valve assembly gates positioned inside the shock absorbers?
  • AHC new model outline.pdf
