LX470 2004 | Need help with Android Screen (1 Viewer)
I hate to ask this, but can you link me to the post with your pictures of where the rear wires should be in the harness? I would like to correct this issue in my truck if possible.
Also thinking about adding a powered sub because the factory sub is not getting it done. I would be curious to see what others have done in conjunction with the Teyes and factory amp.
I emailed them as I’m getting ready to order this unit and give it a go. Asked them if it will be shipping from Australia or elsewhere so i can anticipate the tariffs. The person responding “Nadia” said that i shouldn’t worry because it’s already paid. Not sure what that means
Thanks for linking that! I pulled out my unit and confirmed the wires the need to be moved as described in your post. I tried fiddling with the connector but can't figure out how to free the pins. What is the trick to getting them out?
I used a cheap pin removal tool from Amazon. They only cost a few bucks and make it 10x easier!
Where do you insert the pin removal tool? Front? Back? Little holes in the front above the actual pin holes?
That's the part I'm struggling with.
It goes in the back if i remember. In the same hole as the wire. It took a bit of fiddling so easier to do with the harness out of the truck, but that's a pain too.
Okay good to know. I have a bunch of random dental tools (I'm not a dentist) that come in handy for stuff like this. I'll give it a shot tomorrow.
Once I get the pins out do they just press back into the correct sockets?
Yep. Getting them back in is super easy. They just click in.
Hello all!
I've read most of this thread off/on for the last 9 months (lol) and was wondering if anyone has found a fix for the buzzing noise on a 2007 LC? Last I saw, amp replacement was the only solution? Has there been any new fixes?
Thanks!
Hello all!
Thanks!
That seems to be the only way for the LC
