- Thread starter
- #21
IMHO no it's not. Back in the Stone age a tank was used for impact tools for repair and tire changing but with the advent of more powerful battery powered tools the original premise becomes mute. Look at this way it takes x amount of air to fill a tire now whether you pump it beforehand or on demand still same amount of air. Now if you had an eighty gallon tank sure you could pump it up beforehand but a 1 or 2 gallon tank meh? BUT if said tank was chrome plated that's a different story.
A small tank is not as insignificant as you presume. It's one of the best ways to supercharge an OBA system. Consider the following:
1) 1 gallon is small yes. But 1 gallon @160 psi is worth 4 gallons of air volume at 40psi.
2) Creating a pressure advantage in a small volume tank at a much higher pressure than target pressure can greatly speed the transfer of same volume of air into a tire, versus on demand pumping which probably only creates a 10psi differential if that. Assuming that the pump is still fast enough to recover that advantage between tires. Bigger tank takes a bigger pump, otherwise the tank is just a burden.
My original goal for a small tank was also to support things like an air blow gun, etc. More is just more sometimes, and I'm really liking the simplicity of it all at the moment.
