LX 570 - Yellow Navigation Screen Replacement - A How-To Guide (1 Viewer)
Austin, TX
I recently purchased a 2010 LX 570 to replace my totaled 2009 LX. I used the yellowed screen to talk dealer down some dollars.
  • My first plan was to pull the good nav unit out of the totaled '09 LX and put it in the new '10 LX, but little did I know how much the Nav units varied in the 08-11 model years. The connectors on the back were totally different.
  • The second plan was to buy a nav unit on eBay and eat the ~$1k cost. However, I couldn't find a unit that matched my exact model number and I didn't feel comfortable dropping coin on a unit that might work. The one option I did find looked like its screen was starting to go yellow as well. I'm wondering if this is systemic to the 2010 LX/LC Model Year.
  • Enter the third option: crack open the nav unit and replace the LCD screen + Digitizer. The model is the Toshiba LTA080B922F. I bought it from AliExpress for $171 USD + shipping. Links eventually die, so here is a picture.
@nwfl4runner has done this fix, so I knew it was possible. There weren't any good LX specific guides available, so I cross referenced videos from the LX, LS, and ES platforms. Not gonna lie - this job stressed me out. I'm a 1.5 :banana: mechanic - the most advanced thing I've done is AHC globes/fluid and changing spark plugs. I've never touched a ribbon cable before, and every connector has a slightly different mechanism to release the cable. I almost quit 5 minutes in.
Mission accomplished, though. Here is the result!
And here is a video I put together of the process. Suffice to say, I had no idea what I was doing, so please learn from my mistakes. All you Pro's feel free to chime in on the proper tools and methods that I most certainly botched.
View attachment 3526952View attachment 3526953
You are really great! Is it working well now?
Great job. Something I have on my list. I don’t use that screen except for AC, but the yellow drives me crazy. Prices one the screens are anywhere from $50+. I assume they are all made at the same place, but maybe not?
I’ve seen reports of some people only replacing the digitizer, which is in the sub-$100 range. Is that what your thinking of?
If so, that process involves separating the LCD screen from the old digitizer and glueing on the new digitizer to the LCD screen. I wanted to start fresh on both, so I went with the marginally more expensive Toshiba all-in-one solution.
Ah, you are right. I keep forgetting the yellow screen is the LCD, not the digitizer. You replaced both though. I’ll do the same.
I actually don’t know if the yellow was from the LCD or the Digitizer. I thought it was the latter, but I honestly can’t remember!
The LCD is the screen and the digitizer is for touch control, etc….I THINK.
Yes, that’s correct. I just don’t know which component causes the yellowing. The digitizer sits in front of the LCD. From what I’ve seen, they are connected by glue around the metal edges
Nice work. If you want a cheap upgrade to the feel of your touchscreen, I found that a 7" Samsung tablet tempered glass protector both offers protection to the screen and a more solid response than the spongy plastic. Well worth a few bucks.
That's interesting, did you remove the plastic touch protector or placed the tempered glass on top of it?
Added the tempered glass protector onto the factory spongy plastic touchscreen. Much better response with a glass screen. If you've used an ATM you know how unresponsive those plastic screens are, the LX screen isn't much better. Adding the tempered glass gives you instant response.
I have a 2010 with the yellow screen and it bothers me to no end. Thank you for posting this and creating the video.
One question - will the replacement Toshiba screen eventually go yellow over time as well? Or did they fix the yellowing issue with the updated unit?
Thanks
Thanks
Happy to help!
It's been a while since I researched this, but I think it's the same Toshiba model across all 08-11 (or even 08-15?) models. This would imply a bad batch of monitors from Toshiba around 2010 that was later resolved.
Happy to help!
Awesome, thank you!
I’m planning an update and want to also upgrade with CarPlay. I’m researching if I should replace original screen (like you did) and add something like a Grom unit.
Or
Buy a complete aftermarket replacement that includes a different/new screen and has CarPlay already built in.
Just weighing my options - appreciate your POV.
Thanks again for the help and quick reply!
Probably best to just stick with replacing the screen and digitizer. But, when you had it all apart, did it look like the digitizer could be moved over easily? Or maybe a different direction, did you notice that the new digitizer worked any better?
@Chocolate - Did you have to take the trim off from around the screen to install the screen protector?
I tried the screen protector at the link below on my 2011 LX. It was about 1 mm too wide and tall. With the plastic protective film still attached to the screen protector (practice installs), I could angle and sneak it under the trim to make it fit. With the film removed, the screen protector immediately adheres to the screen, so I couldn't side it under the trim, and broke 2x screen protectors trying to do so.
2Pcs for SAMSUNG GALAXY Tab 3 7.0 T211 T210 T215 Tempered Glass Screen Protector | eBay - https://www.ebay.com/itm/375387729395?var=644348806261
Possible there is some slight size variance in screen protector sizing between brands of screen protectors intended for the Samsung T210 tablets?
