SOLD LX-450 Super Charged, Locked, Lifted (1 Viewer)
SOLD!
Selling my LX450 I was building for an overland rig but have changed plans for
what I want to use for overlanding and this is the reason I'm selling this build.
It has been deflared and from the bottom window line down resprayed. Interior
is in great condition and yes both seats work.
All work listed below was recently done and has less than 50 miles of service.
1997 LEXUS LX450, TRD Supercharged and TRIPLE LOCKED
VIN: JT6HJ88JXV0167430
• 188,425 miles(updated 10/05/2017)
• All main coolant lines replaced
• New Coolant and New OEM thermostat
• New OEM Cap, Rotor, Wires
• New Plugs
• All New Belts
• New Front Main Seal
• New Oil Pump Seal
• New Valve Cover Gasket
• New OEM Oil Filter and AMSOIL
• TRD Supercharger(this unit and all proper parts were sourced used with only 10K miles on the SC)
• OME Steering Dampener
• Iron Man 5” Lift with foam shocks
• ARB Front and Rear Adjustable Panhard Rods
• New DBL Cardin Front Drive Shaft
• Aluminum bump stop blocks on all four corners
• Front Sway bar drop blocks, 2” aluminum
• Rear Sway bar drop brackets
• Stainless Extended Brake lines
• Diff breather hose extensions
• Center Diff Lock
• 7-pin mod
• Breather Snorkel
• All New Crossed Drilled and Slotted Rotors/Pads
• Front & Rear axle fresh fluids
• Brand New 315/75/16 TOYO Open Country (x5)
• LED dome and door lights
• New ARB Front Winch Ready Bumper
• New Custom(fabricator Sean Huston) Rear DBL Swing Out Bumper W/Ladder Basket
• New Melvill and Moon Front Seat Covers – these covers are from South Africa and not
available in the US.(drivers seat has small tear nothing major not all ragged out, passenger seat has no tears and is in good condiditon) Seats are fully functional.
• New Escape Gear Dash Pad Cover with pockets – this is a really cool dash pad.
This rig is back on the market. Couple of changes made to it are:
1. Replaced the center shift console out.
2. Replaced the center arm rest console to a LC80 style.
Photos to come soon.
I'm sure that I'm forgetting other work done and will update posting as needed.
Yes, I have rear jump seats.
I'm located in Spicewood, TX about 25 miles West of Austin, TX.
If you have any further questions, I'll be happy to answer them.
I can be reached at 512-800-8869 - call or text.
Thanks
Archie
Don't see this on Ebay yet. Would like to know if still available.
I can tell you that Arch is a great guy and spares no expense at making things things right. He has some nice vehicles. This is a VERY (too low IMO) fair priced rig for what you are getting. I see folks asking for the same or more that are not SC and have more miles with just a front bumper and lift. Sometimes not even locked.
Buy with confidence here folks.
This is an absolutely beautiful rig...
Original HG? If I missed that my fault; thanks
Not sure, the previous owner said that it had been replaced but had no proof. I haven't changed it. Also I have owned 6 LC80's one had 289k on it when I sold it and have never had to replaced a head gasket.
Arch
512-800-8869
