SOLD LX-450 Super Charged, Locked, Lifted
SOLD!
Selling my LX450 I was building for an overland rig but have changed plans for
what I want to use for overlanding and this is the reason I'm selling this build.
It has been deflared and from the bottom window line down resprayed. Interior
is in great condition and yes both seats work.
All work listed below was recently done and has less than 50 miles of service.
1997 LEXUS LX450, TRD Supercharged and TRIPLE LOCKED
VIN: JT6HJ88JXV0167430
• 188,425 miles(updated 10/05/2017)
• All main coolant lines replaced
• New Coolant and New OEM thermostat
• New OEM Cap, Rotor, Wires
• New Plugs
• All New Belts
• New Front Main Seal
• New Oil Pump Seal
• New Valve Cover Gasket
• New OEM Oil Filter and AMSOIL
• TRD Supercharger(this unit and all proper parts were sourced used with only 10K miles on the SC)
• OME Steering Dampener
• Iron Man 5” Lift with foam shocks
• ARB Front and Rear Adjustable Panhard Rods
• New DBL Cardin Front Drive Shaft
• Aluminum bump stop blocks on all four corners
• Front Sway bar drop blocks, 2” aluminum
• Rear Sway bar drop brackets
• Stainless Extended Brake lines
• Diff breather hose extensions
• Center Diff Lock
• 7-pin mod
• Breather Snorkel
• All New Crossed Drilled and Slotted Rotors/Pads
• Front & Rear axle fresh fluids
• Brand New 315/75/16 TOYO Open Country (x5)
• LED dome and door lights
• New ARB Front Winch Ready Bumper
• New Custom(fabricator Sean Huston) Rear DBL Swing Out Bumper W/Ladder Basket
• New Melvill and Moon Front Seat Covers – these covers are from South Africa and not
available in the US.(drivers seat has small tear nothing major not all ragged out, passenger seat has no tears and is in good condiditon) Seats are fully functional.
• New Escape Gear Dash Pad Cover with pockets – this is a really cool dash pad.
This rig is back on the market. Couple of changes made to it are:
1. Replaced the center shift console out.
2. Replaced the center arm rest console to a LC80 style.
Photos to come soon.
I'm sure that I'm forgetting other work done and will update posting as needed.
Yes, I have rear jump seats.
I'm located in Spicewood, TX about 25 miles West of Austin, TX.
If you have any further questions, I'll be happy to answer them.
I can be reached at 512-800-8869 - call or text.
Thanks
Archie
Is gearing still stock? What is condition of front seat leather? Any known issues?
Gearing stock. Driver's seat has seam tear but not trashed, passenger seat has no tears. I normally replace the seat leather but didn't on this one because of the canvas covers I put on the seats. All maintenance issues addressed when doing build so no.
Wow what a sweet looking rig!
Can I inquire how hard or easy it was to remove the stock fender flares?
Sure, it's pretty easy to remove them but it is hard to do so without something getting broken or cracked.
The section of flare that is attached to the rear doors can also be difficult due to the fact that the bolt that
holds them on ussually rusts and starts to slip.
Arch
LX450 Supercharged, Trip-Locked and Lifted
LX450 Locked and Mild-Lift
How many holes were left and did you use bondo or weld in some metal and prep and paint accordingly?
I can't recall how many holes are left when the panels were removed. No weld up of holes, body shop
used body filler, Prep and repainted the body minus the roof and hood to get a good paint match.
This is a hard color to blend in mid panel so opted against that.
How's the dashboard under that cover? Any cracks?
Nice 80 and I dig the red hazard button, been scrounging old 80's at local yards hoping to find one myself.
GLWS dude, very nice cruiser!
Looks like it sold for $17,600, That seems like a great deal.
