LX 20 to 18/17
East Coast
Hi all, searched to no avail (but I'm sure someone has posted on this)...getting close to needing new tires and asking for first hand experience from those that refitted their OE 20" rims with 18" or 17" OE rims (OE tire size as well).
Can you compare/contrast your on road experience (handling, ride quality, noise, 17 or 18?)? I know I'll get more "spread" when aired down in sand (the whole purpose of doing this).
Thanks so much, leaning toward this rim as easiest (I think) to clean: Premium Replacement 18x8 Aluminum Alloy 5 Spoke Wheel, Rim - 69528 - https://www.getallparts.com/Toyota-LandCruiser-2010_p-30150-premium-replacement-18x8-aluminum-alloy-5-spoke-wheel-rim-69528.aspx?VariantID=147877&gclid=Cj0KCQjwiNSLBhCPARIsAKNS4_fEjAzO0Mb-IRwb87lw9WC1MZOqyN9qmhEKE4zbNkdXmj2qVr_orBYaAnZCEALw_wcB
Hey @LXinOBX I’ve got a lot to share on this and will reply as soon as done working on the truck. Currently too filthy for my office chair!
Alright let's get really, really into it.
So I went from the
OE 21x?"+54 ET wheels on Yoko G056 P275/50r21 XLs 113V
to my
17x8.5" +25 ET Methods on P285/70r17 Toyo OC A/T III 117T
And before i can best answer your question i recommend you read all that I've written on my now admittedly bad fitment choice and the outlined area below.
I even made a stance thread that no one really contributed to with actual stance photos not mountain glory shots if you want to see how these things poke.
In that regard, Ive shared a lot of my experiences and experimentation with the forum to some rather limited feedback so I hope this is a good chance to hash out what is actually on my mind for the sake of this awesome community. Im gonna apologize in advance for the wall of text that is coming.
Please note that nothing in my opinion is directed at the Toyo AT3 which is an amazing tire that I highly recommend.
_______________________________________________________________________________________________________________________________________________________
My objective was to fit the smallest possible wheel, with the largest diameter tire without any rubbing or modifications and get the best ride comfort and fuel economy i could. In doing this I wanted to 1) reduce weight if at all possible. 2) Add as much sidewall as possible.
While I was able to achieve BOTH of those requirements i fell short of my objectives because my understanding was flawed.
The issue is more about the science of wheel / tire fitment and what goes into that choice.
Coming into this i knew practically nothing except how to read tire sizes and have gotten into some back and forth on the forum about how to actually go about doing this THE RIGHT WAY. Part of that is the fundamental principle of what the PSI is to be run on any non OE setup.
There is a lot of WRONG information that is often purported as fact and sometimes (in my case in particular) completely dangerous. There is one particular member who firmly and stubbornly subscribes to a false understanding of the guidelines to appropriate inflation. There is a lot to read on that and many arguments to sift through but suffice to say i fell into that trap myself.
Ive blocked @gaijin so for any other MUD members reading this, please do yourself a massive favor and don't take ANYTHING he recommends as fact. Hes absolutely flat out wrong and even as a complete novice, after a year of research, i have confirmed ALL of my suspicions were true. Heres how i know....
Due to my ongoing struggle of meeting my needs for a comfortable and SAFE ride, I got the chance to escalate my questions to a very very kind and knowledge professional who actually made the tire i own. I spoke to the head tire design product engineer at Toyo. He was kind enough to take an hour of his day to help me figure out why i wasn't satisfied with my setup and how we could rectify it. He was also one of the product managers at Toyota who designed and launched the 200 series, is a huge advocate of AHC (he is the reason the 100 LC received it as an option) and he helped me figure out why my AHC was leaning after a year of pulling my hair out about it. (Thats now solved it and I am going to do a write up on that as i know a lot of the LXs lean to the drivers and probably yours too)
I am super grateful for that opportunity and Toyo/Nitto is an awesome company and I will never buy another tire brand unless i have to.
Basically I was never able to get a comfortable ride out of my tire at any PSI that did not cause instability, poor milage, and tons of sidewall flex.
Here is my new understanding of the situation that I hope will help you make the right choice for you and why i do not recommend any high aspect tire in P rated for our trucks.
First, you CANNOT run a like for like load range tire anything below the door jamb PSI. In our case for any P rated tire, no matter what its load rating is, it must be at least 33 PSI. Going from a 113 to a 117 load rating does not mean you can run it at a lower PSI because it can support the minimum load required for the vehicle weight. I made the mistake thinking that such a large aspect tire at such a low PSI would be an equivalent but much more comfortable change. Boy was that wrong.
According to industry standard calculations which you can do here: RCTIP Calc (just match the load rating if your OE size isn't listed)
My 117T P285/70 can SUPPORT the weight without structurally compromising the tire at 26 PSI which I believe is actually the minimum allowable for the P / size.
At that pressure it rides like a dream on a cloud. The issues however become very apparent when you are actually driving and trying not to die.
When you run such a low pressure you are: creating too large a contact patch and much more friction, removing too much sidewall rigidity, adding too much flex and steering wobble, and creating A-LOT of unnecessary rolling resistance. These things are due strictly to the geometry and forces at work. Thats it. They have nothing to do with the tire or the vehicle. Its just a function of how much downward force is applied to the wheel, the lateral forces to the sidewall, the amount inner surface area the air is occupying, the contact patch that creates, and the heating and cooling of the tire as it tries to absorb all that.
I noticed from playing with it so much that it did not drive well at anything below about 32-34 PSI. I actually almost crashed doing some experimenting during a turn.
Now any actually competent tire recommendation will tell you the same thing, which is why i was so confused when Discount Tires store computer database suggested my pressure to be set to 32 PSI.0 To put it very simply, just because the tire can roll and not explode or de-bead at 26 PSI does not mean you can simply expect a 6,500 lb vehicle to handle on that. When OEMs choose tires and their respective pressure, they are trying to achieve a balance of the all of the above and more (things like rebound rate which plays into suspension damping and a whole lot stuff we can discuss later). When you try to get a large tire and run it low, you throw all that away.
Dont fall victim to the idea that you can just create comfort by dropping PSI like I did.
To understand this better let talk about comfort. Tire comfort itself is due to a multitude of reasons but mainly to two things; the construction, and the pressure.
These two things are inextricably linked and simple enough. The more robust carcass can handle more internal pressure (although absorbs more heat and thus these why LT tires all have lower speed ratings)
As far as construction goes, we know that there are equivalent ply ratings, compounds, tread geometry and so on. These things are pretty much as they seem. Its when we get into pressure that it gets more interesting... As you can see above, i thought a lot of what was obvious to me was straight forward to understand and linear in logic. That is not the case. The thing that helped me the most was understanding that pressure alone is not enough to judge how soft the ride will become.
Let's take the example above and dissect it a bit. I have an OE 275/50r21 at 33PSI, it has a 5.4" sidewall due to the aspect. Now take a 285/70r17 at that same pressure with a 8" sidewall. Which one would have "softer" ride? The 8" sidewall you say??? Shouldn't they both offer the same softness as there is the same pressure of air holding up the car? No. Actually you are right to think the 285/70 would be softer. The question you have to answer then is why? Why with the same forces of air is one softer than the other? What i was explained and have since read more on really helped me understand and make my choice of a new C load AT3 very easy.
(BTW as soon as these are installed next week I will add more to this thread).
Pressure alone does not dictate anything but instead its the pressure relative to VOLUME. While I don't have the formulas or know the details, this is apparently part of how the load ratings are calculated in the first place. When a plus size P anything tire is given a higher load rating, its not because of any additional pressure capacity. As a matter of fact my old yoko 113s could get up to 50 PSI while my current 117s can only recieve up to 44. This also confused me before.
We all know the it's the PRESSURE holding the vehicles weight but there is more to it than just that when it comes to comfort.
When a particular tire is inflated to a particular pressure of air, that indicates of how much air has been squeezed into it. We also know that air is compressible.
When you try to compress a filled tire, you are working against that total pressure and construction pliability but its really the volume / quantity of AIR inside that has the capability of compressing as well as the overall size of the tire itself that can stretch accordingly. The more actual air is in there, the more empty space between the molecules that can be compressed. Comfort is much better accommodated when there is a larger volume of air and tire to create it.
It's easy not to see that, but likewise its very clear now that i have my head wrapped around it.
So, long story short, I do not recommend running a P rated tire if you are looking for comfort. You will have to fill that to a HIGHER pressure than you think in order to preserve everything other than comfort and will be way too close to the max PSI when at operating temp. For example, our manual states to fill rears to 39 PSI when towing. That would be an absolute joke to do on a tire with a max PSI of 44 for the towing stability. I would rather recommend you fill your tires to a lower percentage of max than that. I will be going from my Ps @ 77%-82% fill (32-36 PSI/ 44 MAX) to a more comfortable C @ 72%-80% (36-40 PSI/ 50 MAX).
I never thought that a C tire would be the right choice for comfort for me but when you apply the principles of tire engineering CORRECTLY you will see that you really cant cheat the system like I thought I would be able to do. As a matter of fact, if you use the calculator or do it by a hand per the Toyo RCTIP Guide I can run a C load at a safe minimum (equivalent of OEM) of 38 PSI safely and due to the inherent stiffness in the LT variant will probably achieve a more stable ride even at that. Even better than that calculating the OEM towing recommendation of 39 PSI gives a safe minimum of 40. This is giving a useable and safe running PSI range of 12. On the Ps i would have only have a safe range of 10 and a usable range of 8 when starting at 36 PSI (where i know the tire is handling best). Also when off-road, your LT metric will also be much less likely to de-bead due the additional sidewall materials and bulk. Im a mall crawler so i cant comment exactly, but Ps aren't gonna roll off the wheel and people do run them but LT is going to be safer for that nonetheless. Lots of other stuff about punctures you can dig up too but thats another topic.
Now in your case heres what i would suggest.
Don't try to reinvent the wheel and definitely ditch the 20s. There is just too much bump steer, they are too heavy for what they are and ride like trash and will do you no good off-road. They also don't do the AHC any justice, but if it weren't for AHC Lexus would be shipping 18s.
Speaking of, dont get 17s. Get 18s.
With the bigger brakes of the '16+ years there is NO room to clean anything at all. I can barely squeeze in my smallest wheel woolie.
In addition 17s don't look right on the LX and i regret that from a style perspective. I think 18s look perfect.
I only went 17s because i found the only non Rock Warrior wheel in a proper offset that weighed the same.
People will differ here, but I don't like spacers. I would rather just get the right wheel and Rock Warriors are not my cup of tea anyway with the locker ring and rivets.
I shaved 10lbs a corner and honestly still suffer a loss to MPG due to going 285 wide, the tire lift, and the pressure situation being more resistive.
I highly suspect when i add that 9lb for the C load back that with less flex of the tire, my efficiency will be practically unaffected as i can keep the tire more "round".
THE BEST offset for the platform, again IMHO, is +35. If you look at my stance thread i poke ever so slightly enough to make a mess of my body panels. Unless you get PPF applied or large mudflaps i would go less wide. +35 would tuck perfectly and an 18x9 wheel would fill the well just right. I would look in the tire and wheel database to see if that will rub being .5" wider and .4" closer to the hub. Definitely don't get the ones you linked. That is not going to fit larger tires at +60 ET unless you want spacers. But also what do they weigh? Its VERY difficult to find weight specs on any wheels. Part of the reason i went method is its all listed.
In regards to wheel width let me say this very clearly and I hope i can get others to comment.
An 8.5" wheel IMO is not enough width for a 285 tire. A general rule of thumb is you want to achieve as square a tire/wheel profile as you can while maintaining a good bead angle and pressure. As it is now my tires have to curve back into the wheel more than 3" in order to fit into the 8.5" wide bead. Toyo suggests a 7.5-9.5 " wide wheel for my size tire in their specs but I would bet that they er on the side of caution for bead friction.
Next time around i will lean more to the larger number than the middle and thats 9". If you want photos id be happy to show you what I mean.
In regards to wheel weight, I have found that going lighter is not always the answer in a TUNED suspension like ours. I firmly believe that you should stick as close to the OEM fitment weight as you can on your LX and definitely try your best not to overly exceed it. At the acceleration that a wheel typically engages with the shock, 10 lbs has a lot of impact on the forces transmitted. When i dropped weight on my setup i constantly experienced the damping to be more muted as the shock was fighting a lot less and felt like the truck was over-sprung. I have learned that In an actively damped tuned suspension like AHC, the fluid and gas pressures are receiving a lot less force than they were tuned for at our different settings. Comfort feels a lot more like normal did in damping (not harshness of ride). I now know better than to try and cheat that system as well and im getting back to my OEM 80LB per corner. As it is now I would never want to live in comfort mode as there is too much brake dive. I need the weight to plant the vehicle and actuate the shocks the way Lexus intended. If we had more control over AHC i would not be saying this. Sometimes i wish i didn't have it for build out flexibility but it is just so damn good and practical.
Now onto tires. I CANNOT RECOMMEND TOYO ENOUGH. Not only do they make excellent tires but i assure you they care about this community and consider all that it is we care about too. The OC AT III was partly designed by a land cruiser lover and is quickly becoming a forum favorite.
I would say the only negative i have with them is they are a bit noisier than i thought they would be and the sidewall is not the most aggressive. I dont have the most experience on AT or Hybrid or Mud tires but there are many here that do. What i do know about is the huge experience i had above and this vehicle in particular which we share ownership in. I have made several posts about how good my tires were specially in the TX freeze where i live in a very hilly area. I was blown away by snow and ice performance climbing hills like it was nothing while cars were piled up at the bottom including a g-wagen. Im not sure about sand performance but I know the tread pattern is damn well thought out in all the right areas. @bloc has a lot of experience with his and generally off road tires so he can comment on his opinion and comparisons as many others here too that run them, @TeCKis300 included.
TLDR;
If i were you, sand running aside since those require a very odd type of tire, i would go with a Toyo or Nitto in 285/65/18 in a C load or above on an 18x9 wheel that you like in a +35 offset that weighs no more than 30lbs. You should also note that since you came from 20s and I 21s with very similar tire diameters if not the same, your speedometer will be almost accurate. We are lucky in this fact above LC owners since they all come with 18s. My gas milage is pretty much 100% accurate too.
This is the longest craziest post ive made but after a year of thinking about this and working on it im finally at a place of peace and wanted to share with this awesome community and actually give something back. If we can make a standalone thread on this for the LX i think it would be super helpful as the inlfux of LXs specially '16+ will only increase from here on out and the 200 never got AHC.
Also cheers and welcome!
So I went from the
to my
I never thought that a C tire would be the right choice for comfort for me but when you apply the principles of tire engineering CORRECTLY you will see that you really cant cheat the system like I thought I would be able to do. As a matter of fact, if you use the calculator or do it by a hand per the Toyo RCTIP Guide I can run a C load at a safe minimum (equivalent of OEM) of 38 PSI safely and due to the inherent stiffness in the LT variant will probably achieve a more stable ride even at that. Even better than that calculating the OEM towing recommendation of 39 PSI gives a safe minimum of 40. This is giving a useable and safe running PSI range of 12. On the Ps i would have only have a safe range of 10 and a usable range of 8 when starting at 36 PSI (where i know the tire is handling best). Also when off-road, your LT metric will also be much less likely to de-bead due the additional sidewall materials and bulk. Im a mall crawler, Ps arent gonna roll off the wheel and people do run them but LT is going to be safer for that. Lots of other stuff about punctures you can dig up too but thats another topic.
In regards to wheel weight, I have found that going lighter is not always the answer in a TUNED suspension like ours. I firmly believe that you should stick as close to the OEM fitment weight as you can on your LX and definitely try your best not to overly exceed it. At the acceleration that a wheel typically engages with the shock, 10 lbs has a lot of impact on the forces transmitted. When i dropped weight on my setup i constantly experienced the damping to be more muted as the shock was fighting a lot less and like the truck was over-sprung. I have learned that In an actively damped tuned suspension like AHC, the fluid and gas pressures are receiving a lot less force than they were tuned for at our different settings. Comfort feels a lot more like normal did in damping (not harshness of ride). I now know better than to try and cheat that system as well and im getting back to my OEM 80LB per corner. As it is now I would never want to live in comfort mode as there is too much brake dive. I need the weight to plant the vehicle and actuate the shocks the way Lexus intended. If we had more control over AHC i would not be saying this. Sometimes i wish i didn't have it for build out flexibility but it is just so damn good and practical.
TLDR;
TLDR?
LOL that makes sense since I know you're savvy on internet thangs.
Its a yuuuge post. Had my best people on it.
So I went from the
to my
TLDR;
A lot there the unpack. Thanks for sharing a lot of the learning you did. I won't comment on it all, but there's some good nuggets in there.
- I've attempted to push back on the RCTIP interpretations on these boards. While generally an okay starting baseline, it shouldn't be taken as gospel and definitely has its limitations. Unknowingly, some are running way too high pressures that can be unsafe with sidewall spring rates that some suspensions, especially stock, cannot handle with tires skipping down the freeway with poor to dangerous traction and handling. On the other end to your point, wind up with far too low of pressures and handling stability is compromised.
- Be careful with the offset interpretations. There's no magical singular offset and it's dependent on tire overall diameter. I'll say some of your impressions may be due to too aggressive an offset. For a 32.8" tire, should be closer to +45mm.
- Wheel width and diameter are variables to be considered and tailored for use. IMO again, there's no singular magic size here. For on road, larger and wider wheels can have significant benefits to stability. Off-road, we know generally more sidewall and perhaps narrower wheels (to an extent) can help, but at a trade to on-road. I would agree with you that generally an 18" setup is pretty good. Be cautious about too wide a wheel and too narrow a tire as this combination can tend to loose beads more easily off-road when aired down.
- AHC is magic. On the other end of the spectrum to your impressions of a lighter and smaller wheel tire package, for those running really large and heavy setups closer to 34 or 35s that weight in excess of 100lbs - when going fast on really broken pavement, contrary to intuition, it can help to use sport damping. Because of the heavier tire the extra damping can help better control the wheel/tire in the bumpy stuff.
Where I couldn't agree with you more is the Toyo AT3s. Excellent all around tire, isn't that what All-Terrain (AT) is about?
I slapped on some 18 inch Land Cruiser rims the month I had my LX. Easy to find (mud member) and they look nice. I painted them bronze and left the Toyota center caps (not dropping $200 on Lexus center caps) Better tires selection, better ride, you can actually off road and tires are less expensive.
I get why people like the 20s, just not for me.
Thanks and you're absolutely right.
I did not mention suspension geometry, scrub, and length of lever arm impact that offset makes among other things.
It can change handling characteristics, cornering, stability and comfort. I would have brought that up but will leave it to you,
my knowledge of suspension design is just not there yet. (Although I am having a blast learning about watts links and how that could apply to AHC).
I will say there is a definite need for track width increase on the platform but most of what the +35 recommendation is about tire fitment and stance. As far as a singular right offset, there is no such thing i agree. I also know that in a double link suspension you want some positive scrub if im not mistaken. I don't think +25 works best for this size and +35 is a good in between to avoid zero scrub which im assuming your suggesting at +45.
AHC is magic. In sport sometimes i cant believe the flat cornering I can get. Its dumb and ive never been in this size/weight of an SUV that felt that way.
Boy that was a lot. My only real comment would be to step back a little and realize you made it sound like there is only one option… 18x9ET35….I’d be surprised it you needed more than one hand to count the options available in that size Wheel. Lots of guys on here run out to ET25, and that would be my comfortable limit. But offset can’t really be suggested until a tire height is chosen, and is still at the mercy of availability.
I’ll say my knowledge is novice level, but my experience definitely lines up with a lot of the things you’ve written above. I personally think the 17” wheels are best option, but I don’t spend any time trying to polish the inside of my rims. They fit and they maximize the volume of air for all that sweet air squishing comfort. Plus as great as it is shopping for ATs for 18” wheels, it’s even better for 17” wheels. More options and cheaper.
if I was looking for a cheap abundant Toyota wheel, I’d def be looking for that 5 spoke Tundra/Sequoia aluminum wheel. 29lbs and can be had for $100/set pretty regularly.
im interested to hear about your fix for the lean. I’ve come to assume it can only be fixed with spring shims or some other way to adjust the spring loads.
Thanks all! Really appreciate the comments/guidance. I should have posted that my tire size choice is (and would be in 18 ...or 17?) OE
Any chance you could post a pic of your bronze wheels? I'm thinking of going this route and am struggling to find pictures through search that aren't Heritage wheels.
Here you. I just looked at the colors available at the rim shop that painted the tires and picked this one.
If staying at OE sizes, then all the talk about offset is pretty moot. This is the wheel i was going to go with before finding a cheap set of RWs. 18x8 ET60 and reported to be around 29lbs. I see these in my local used markets for $100/set.. Maybe $200 if they are new takeoffs and in perfect shape.
Oh, and I should answer the original question. Going form 20" wheels and OE tires to 17" wheels (with + size tires) made a huge improvement in NVH for me.
Absolutely.
This is more for the instance of later year LX (BBK), and with a plus one size 32-33" tire to avoid fitment mods while also considering AHC.
I will say that IMO and this is strictly my personal experience that in general on any LC the factory offset is not good. Its too conservative and some added width is actually needed. Your point on tire and wheel options stands. In 5x150 lug patterns, there is a pretty limited amount of quality wheels out there but I will say the tire choices are increasing steadily.
Like I replied to @TeCKis300 it also does not really achieve the perfect factory geometry. Part of the issue with that is also AHC.
When you do end up doing a sensor lift like most here would, a lower offset would actually help offset the effects of the added camber. Pun intended.
This in itself is a lengthy conversation because unfortunately with any lift, a proper alignment becomes much more difficult to achieve and cant really be done to OE spec.
This is actually why I have left my AHC at factory height until now that i have the truck balanced and leveled and will be done once i get the rake angle front to rear where i like. I will be going to a local truck outfitter once I'm done with all that (still doing research on it) who will do a proper camber adjustment alignment like they would custom trucks and aligned at Normal ride height. I will also be adding additional caster to bring back a more quick torque neutral steering rebound.
One of the things that i really liked about the 300 suspension is the reduced shock angles. This could potentially make the wheel travel more linear and would help in all of the specifics outlined above. Hoping to see some show up to the forums soon.
As far as the AHC leveling. Match the rear springs. Thats it. It was just you and I suspected. I bought an additional pair to have a soft and firm option and I prefer the twin tall setup. Now my HOU does not fight the load and my pressures should be all in line. When i go from L to N there is no adjustment period. The shocks pressurize and come up level and stay there. No weird behavior. No more depressurized sag when shut off and parked with the release whine.
The rear left shock was doing way more work than it needed to.
Hey brother if you dont want to plus size, I would search the classifieds here and everywhere else for 18" LC or tundra takeoffs. They should be abundant and cheap.
I have 3 sets of tires/wheels for my LX.
My summer set up
OEM 20” with KO2s in 275/60-20, due for new next summer.
Winter set up
18” tundra takeoffs Hakka 7 265/60-18
I gave up on RWs as my new summer set up so got another set of 18” tundra take offs, they came with defender LTX in LT 275/70-18.
My winter set up rides the softest by a long shot due to my Hakka’s being p metric. The defenders are way better in the sand then the KO2s. But not surprising since sand tires do not have aggressive tread. I used the LTX for about the last 6 weeks of summer, really solid tire. Used them during hunting season going up to sheep base camp did just fine.
snip//
snap//
Thanks for sharing your experiences, but here to disagree that you need additional width from the wheel. Rock Warriors (+50) are proven and the stance you refer to seem more about your preference for appearance than experience.
