Lutz Auto - Speedometer Correction Device (11 Viewers)
@lutzI see on your website the tags include HD models. I have a H1FA part time transfer case. Will the 80 series one work for me still? Thanks
We are pleased to bring you the fully plug-and-play Lutz Auto Speedometer Calibrator for 80/100 series landcruiser's/LX's. This speedometer calibrator is fully adjustable and has no latency issues. After installing and calibrating it, you will forget that it exists! Ships quickly from the central coast of California.
80/100 Series Landcruiser & LX450/LX470 Speedometer Calibrator/Correction Device | Lutz Auto - https://www.lutzauto.com/product-page/80-series-landcruiser-lx450-speedometer-calibrator
Hello. Yes I ordered one of these and fitted to my 100 series landcruiser in NZ. Works a treat. Thanks.
1996 FZJ80
I just installed my new Lutz kit last night.
Took about an hour because I had trouble unplugging my original harness due to tar, gravel, and other debris caked on the plug.
I knew my number was 5% so as soon as I had it connected, poked it 10 times, installed the cover, and drove it. Right on the money.
Running Goodyear Duratracs 285/75-16.
It's my DD and I've had years that I drove more miles to deduct for business than my odometer showed, so I needed to correct it. I run about 15K-20K miles per year, so it can add up for deductions.
I zip tied my control box to the fuel lines.
I wrapped all the plugs and open loom with 3M Super 33 black electrical tape, then zip tied the OEM harness to the Lutz harness to keep it all out of harms way.
I used a tiny bit of dielectric grease to keep the plugs lubed and to assist keeping out moisture on the seals.
Took a couple weeks from date of order to receiving it, but that's ok. Part of that was USPS.
Probably one of the simplest mods I've done.
Hi, yes. This is completely resolved.
The LX470 does use the abs sensors to get speedometer speed, so this unit won't work for am LX470. We are currently working on a unit that will correct the speedometer on vehicles that use the abs wheel sensors. We should have something dialed online by the end of the year.
Thanks for confirming. Definitely interested. I’ll keep an eye out for an update.
Installed this a few weeks ago on my lx450. Now the first vehicle I've owned that the speedo is dead on. So satisfying.
Hi, I just re-read this and realized I made a mistake... The LX470 works fine. We have sold many of these units for the LX470.
I must have been tired when responding!!For some reason I was thinking LX570 because I was working on a solution for these vehicles...
Glad to hear it! To confirm, I shouldn’t expect any issues with cruise control if this is installed. If I’m lucky and I do get the issue described in this thread, what is the resolution?
There are no cruise control issues. We have resolved this long ago. Our speedo calibrators are programmed so that they will not let any oscillation exist.
