LS3 C&C Automatic VS Manual.... thoughts?? (1 Viewer)
WSOPgold2012
MoxieMan
Front Range
What are the Pros/Cons of each? All opinions appreciated.
I have swapped a truck or two and I can tell you my favorite is a 6.0L with an NV4500 trans. What a blast to drive. I've put together a 5.3L and Toyota 5 speed and I can tell you that I personally prefer the NV4500.
I have done both lq4 with cam swap nv4500 4:10 gears / lq9 no cam swap 4l80e 3:70 gears both haul ass for sure. There something to be said about down shifting from 5th gear to 3rd gear at 6000rpm will definitely surprise a vet or comaro for a minute. The auto gets down too shifting from 1st to 2nd takes a minute and will make you let off the gas a little to go ahead and upshift into second before speeding ticket. The manual I have never rsn 4th gesr sll the way out just 3rd plenty fast enough to loose your driver license. The owner @Str8Razor has ran 4th out. Oh yea did i mention burnouts.....
Thanks guys....im kinda a "manual for trucks" sorta guy....HOWEVER, remote start is veryyyyyyyyyyyyy appealing at 9600' in Colorado Nov-March. Sooo awesome to have such decisions to ponder.
What about going with a 408 rather than a Ls3? The more cubes the more torque down low. Just a thought.
I can barely spell LS3...no idea what a 408 means or is. Is it sold new? The LS3 is sold brand new as a package...That sounds appealing. Pretty sure the torque of the LS3 will be a MASSIVE upgrade from the OEM Motor.
A Ls3 is a ls engine that is 6.2 liters. The benefit of going with chevy directly is its all new and ready to drop in. I personally would go the erod route if I was doing that because the emissions compliance would increase the value of the cruiser a lot. A Ls3 will be far more powerful, but it is a corvette motor, so the camshaft is made for hp rather than torque. Of course a different camshaft would help change that. A 408 is a 6.0 liter Ls engine with a stroker crankshaft which turns it from a 6.0 liter to a 6.8 liter or 408 cubic inches. You can buy a new 408 motor on summit racing and places like that or just have a machine shop build one for your needs. If your at 9600 feet, that altitude is going to suck a lot of power. A bigger motor will help offset that. But yeah all ls motors will be a huge increase in power. I was up by Eisenhower tunnel recently, and I was amazed at the power loss in my 6.0 liter. I think it's something close to 40% loss in power at those elevations. The negatives of going 408 is its not a factory built motor.
I just swung this into my 62 yesterday. NV4500. They are very stout and although the gear spread is not as "nice" as an H55 an LS V8 doesn't care. Especially an LS3. I have no love for 4L60s. If you are doing a GM engine there are 2 proven options IMHO, NV4500 or 4L80.
If it is the convenience of getting into a warm truck you're, look into getting a coolant heater and or oil pan/block heater. Heat right away and less wear on start up.
Whats the 4L80?
So, the Auto transmission that is sold with the LS3 isnt "proven"?
Take a look at one beside a 4L80. Take a look at one beside an A440. Pick one of each up into the back of a pickup. Take them apart and have a look inside...
They're not a heavy duty trans like the 4L80. You can take a stock 200k mile 4L80 and put 15,000 lbs behind it and tow across the country, or put it behind a 650hp turbo LS engine and take it to the drag strip every weekend for years...
There is a good reason many commercial users really like and hang onto GM trucks and vans with the 6.0/4L80. They are about as bulletproof as you can get with none of the high-dollar repair bills of a diesel.
The gear ratios of a 4L60/65 have a lower first and taller overdrive though. The newer 6 (and higher) speed transmissions are also becoming more popular with swaps but many people not using a complete factory crate package have had issues making them work, and they're not as affordable as the 4L60/4L80.
If your expectations are to use the truck not much harder than your average soccer kid SUV, and 150k miles is an acceptable lifespan - then go for the soccer kid SUV trans. If you want the ability to beat on the truck like the convicts at Bubba's Landscaping do on the daily, and you're gonna be pissed if it doesn't last 250k miles, skip that half-ton stuff.
Just Google 4L60 meme. The internet doesn't lie 😅
