- Joined
- Jul 22, 2012
- Threads
- 585
- Messages
- 16,549
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
This is a setup I came up with to use GM-style engine mount, Anchor part # 2909, found on virtually all GM trucks and SUV's equipped with LS-style engines from 1998 to about 2013. These are commonly found and a great mount to use for your swap. However, they can be tricky to use for your project because of their odd angles, so I made this kit to help with that. The sheet-metal components are laser-cut and press-brake bent from 3/16" steel. The middle raised section has the M10 nut welded for easy installation.
This kit provides the correct 1.5" engine offset to the driver's side of the vehicle so the transfer case stays in the correct left-to-right plane.
The next ones that are being made now have the frame stiffening plate extended 4" forwards to provide space for conversions using the NV4500 transmission or Ranger overdrive which require the engine to be located farther forwards in the engine bay.
I'm going to start these out at $200 shipped in the lower 48. Components will be shipped unwelded.
Let me know if you have any questions!
Matt
Matt
