Low Speed Steering Question (1 Viewer)
Pittsburgh, PA
I have searched but not come up with any useful information on my steering symptoms specific to the GX.
Unfortunately I cannot say exactly when this "started" as I think it has always kind of been there, but since moving to an aftermarket suspension the feeling has become much more apparent. (6112 w/650lb springs, new OEM LCAs, JBA UCAs, ITRE, OTRE, no sway bar, Marlin Crawler HD LCA Brace Kit, alignment, etc.)
During low speed, "harsh" bumps the steering column has a "clunky" feeling. There is no audible clunk, just feels clunky if that makes sense. It is not side-to-side slop, it is vertical "slop" (and I hate to use that term because the steering feels tight horizontally). It is most noticeable on fire roads/trails with baseball-softball sized rocks throughout. It feels similar to my 01 Tacoma did prior to adding a tack weld to the slip joint in the steering column.
Anyone else experience this? Am I missing information on a well known characteristic of these trucks (I hesitate to call it an issue because I have a feeling this is a purposeful feature of the steering column. I.E. play from the rag joint).
The sector shaft could have too much play. They do go bad. You can inspect it easily enough under the hood.
yes...
