I'm slow. And go through spurts of motivation. It was warm here recently and I've been away from work more to help with kiddo while she deals with her mom.....that's a whole 'nutha story.
The Goblin will ride soon......
I think I've worked out my 2 major speed bumps this week.
1. Clutch slave was way off, and wrong before, and wouldn't work with the bracket. Also. The p/o's hacked most everything into place. I had to tap and helicoil 4 threaded holes. But the slave and starter are both mounted and secure. I think. Even tho a friend decided to "tap" a bolt through the starter ear and cracked it.....
2. I also hacked and modded a stock battery tray. Thanks again
@77TLCFJ40
I had to figure something out. Didn't want to go back under the seat as the p/o had. What a mess. The v8 poses proximity challenges and doesn't allow for the battery and oem tray to sit in the stock spot. I cut out a section to allow for spark plug changes with battery out. And then I welded on some 5" risers and a couple slats. Made from some angle iron and flat stock. I think it will hold. I will bolt the oem lower bracket in about 4 spots as normal and should be good to go.
All wiring is back in and wrapped in 2B approved electrical tape and all that is left is the rear section for the tail lights.
Fuel lines run. New pump. And pick up in the re-coated 20 gallon rear mount tank.
Seat frames powdercoated. New vinyl on seats. Oem vinyl was under the slip covers. So. They do have the same stitch pattern that was on there originally. I think.
I am going to take the jump seats to be recovered in matching gray once it's up and running.
Left to do:
-Fuel pump power.
-Figuring out which wires to put on starter and set distributor.
-couple of other small wiring things to sort.
-route plug wires
-bleed brakes and clutch slave (double check slave for clearance----shhhhh is tight)
-Needs exhaust/muffler
Couple pix.
#goblin
