Trying to diagnose a starting/idling issue with my 1HZ that popped up recently. Looking for advice on where to start....
I had removed the ACSD awhile back and bought a block off plate to go in its place. After the swap, I primed the fuel filter button until i felt resistance and the cruiser started right up, no issues. Didn't drive it much for awhile. Didn't re-time the pump, but it seemed that it ran the exact same and normally. The ACSD was completely locked up and frozen when it was removed.
A few months later, it feels that it takes a lot of cranking to get it to fire up and the initial idle is rough and I have to run it at about 2000rpm for about a minute to clear it out.
I started checking the primer on the fuel pump in the mornings and discovered it will take over a dozen pumps to get it hard again and then it starts just like she used to.
Idling in traffic during red lights the idle will start to intermittently cough or stutter but come right back.
So, I deduced that it is losing pressure somehow after I park it for the day/night. The occasional idle stutter in traffic makes me think it loses pressure pretty quick.
First thing I tried was removing 3 glow plugs and trying to bleed trapped air. Didn't appear to have an effect.
I have a set of new replacement injectors in my parts stash, and have ordered a new fuel filter top/pump.
My plan was to replace the filter top/primer pump in case it is bad, then the injectors in case they are leaking down? Is there anything common or obvious that I should try before sending the IP out to be rebuilt?? I was surfing some Ford IDI forum posts and saw that the return line check valve is the problem with them. Does the 1HZ IP have this issue?
appreciate any help or pointers.
EDIT: found this thread
forum.ih8mud.com
So maybe the rubber lines between the IP/hardlines/fuel filter and even the water/sediment trap in the bottom of the filter?
1HD-T - Possible air leak from fuel primer ?
