The cruiser hasn't been starting up as quick as she used to, being a Di she used to fire as soon as i flicked the key, now it cranks for a couple seconds. I don't know whether it is an air leak or a dying starter, batteries are only a few months old and it had a rebuild 10k/km's ago, drives mint and uses bugger all oil.
I had a quick look around the fuel system today and noticed a bit of diesel under the fuel filter, I had a leak from the water sensor were the wires come out a few years ago that caused similar problems but alot worse, it was underpowered and idled low then, I ordered in a new one but araldited the old one up which done the trick.
The sensor was definitely weeping again but not as bad so I replaced that with a genuine one today along with the filter hoping it would rectify my starting issue, I also purchased a metre of clear hose. Fired it up and it was the same, but there definitely appears to be a fuel delivery problem.
Before the video I did it with the injectors cracked, definitely got a lot more air out but there was always a small bubble right at the top of the hose at the primer outlet after running it for 1min or so it was back to where it was where the video starts. I have clear hose on the other side of the filter and other than a couple of minuscule bubbles there appears to be no drama's with fuel delivery on that side. There was a minor leak out of the clamp on the pump in thee vid that was sorted and made no difference either.
Regardless of whether it fixes my starting issue or not I guess I just want confirmation that the amount of air in the line isn't normal, and the best way to go will be to replace the primer housing ?
Also any other suggestions for possible causes for both the air in the line and the starting issue more than welcome ?
